speed droped
richierich007
speed droped
hi all... is it poss you could look at my line stats ... speed has just dropped I was hitting about 70/18 now its 3.5/18
the router went missing on the lappy , I rebooted router and lappy and the connection came back, but as u see the speeds have vanished,
also Or aee working in the next st up from me , im sure my cables are routed there
Fixes: 238
Re: speed droped
Hi there.
It looks like your profile changed back to its old ADSL value for some reason.
I've changed it back to normal for you and if you reboot your router or log into it and disconnect then reconnect it should be fine.
 Matthew Wheeler
richierich007
Re: speed droped
as expected from Plusnet super quick response and fast solution , thanks Mathew , everything back to normal ,,, BIG thumbs up
Fixes: 238
Re: speed droped
Fantastic!
Glad to hear everything is back to normal Smiley
 Matthew Wheeler
