speed droped
- Re: speed droped
speed droped
23-01-2015 10:58 AM
hi all... is it poss you could look at my line stats ... speed has just dropped I was hitting about 70/18 now its 3.5/18
the router went missing on the lappy , I rebooted router and lappy and the connection came back, but as u see the speeds have vanished,
also Or aee working in the next st up from me , im sure my cables are routed there
Message 1 of 4
(477 Views)
3 REPLIES 3
Re: speed droped
23-01-2015 11:04 AM
Hi there.
It looks like your profile changed back to its old ADSL value for some reason.
I've changed it back to normal for you and if you reboot your router or log into it and disconnect then reconnect it should be fine.
Message 2 of 4
(261 Views)
Re: speed droped
23-01-2015 11:25 AM
as expected from Plusnet super quick response and fast solution , thanks Mathew , everything back to normal ,,, BIG thumbs up
Message 3 of 4
(261 Views)
Re: speed droped
23-01-2015 11:25 AM
Message 4 of 4
(261 Views)
