speed cap
carl0s
speed cap
Hi.
After tidying up wiring and things, our line has been synced at 39,999 for a good while and with rock solid stability (anybody looking at stats, please note that the electric company turned the power off at 9am this morning until 1pm).
I have a static IP, I think I read somewhere that this has a bearing on a PlusNet speed cap.
The PlusNet portal says "
  • Current Line Speed (Download): 36.6Mbps"
also BT says the IP profile is 37.5Mbps
I have never managed to get more than ~36 through the line even when synced at 39,999, so I think these caps and profiles are losing me approx 10%.
The attainable rate is actually about 42 megs, but I seem to be on a 40 meg package, there was no option for a 'Fibre Plus' or 80 meg package when I ordered and there isn't an option to change to that, that I can see.
It's possible that if I was put on to an 80 meg package, and the DLM tried for a 3dB profile, I might even see 44 or more mbps.
Could somebody please look at my account and see if something can be done to improve it? I think the line exceeds Openreach's expectations. We moved in here at the end of October and ripped out loads of internal wiring. It was like a 1970s hotel!
4 REPLIES 4
notmyname
Re: speed cap
If you're only seeing a max attainable of 42mb on a 6db profile, I'd expect you to be quite some distance from the PCP. With that in mind, changing to a 3db profile is just asking for trouble.
carl0s
Re: speed cap
OK. If that's the case, it would still be nice to just get the 39,999 that the line is synced at with the current profile. i.e. raise the IP profile and remove the plusnet 36.6 cap.
xdslcmd: ADSL driver and PHY status
Status: Showtime
Retrain Reason: 0
Last initialization procedure status:   0
Max:    Upstream rate = 8067 Kbps, Downstream rate = 43556 Kbps
Bearer: 0, Upstream rate = 8067 Kbps, Downstream rate = 39999 Kbps
Bearer: 1, Upstream rate = 0 Kbps, Downstream rate = 0 Kbps
Link Power State:       L0
Mode:                   VDSL2 Annex B
VDSL2 Profile:          Profile 17a
TPS-TC:                 PTM Mode(0x0)
Trellis:                U:ON /D:ON
Line Status:            No Defect
Training Status:        Showtime
                Down            Up
SNR (dB):        5.7             6.0
Attn(dB):        25.7            0.0
Pwr(dBm):        11.8            4.3
                        VDSL2 framing
                        Bearer 0
MSGc:           -6              26
B:              162             245
M:              1               1
T:              0               37
R:              8               8
S:              0.1295          0.9685
L:              10564           2098
D:              4               1
I:              171             127
N:              171             254
Q:              4               0
V:              0               0
RxQueue:                135             0
TxQueue:                27              0
G.INP Framing:          18              0
G.INP lookback:         27              0
RRC bits:               0               24
                        Bearer 1
MSGc:           90              -6
B:              0               0
M:              2               0
T:              2               0
R:              16              0
S:              10.6667         0.0000
L:              24              0
D:              1               0
I:              32              0
N:              32              0
Q:              0               0
V:              0               0
RxQueue:                0               0
TxQueue:                0               0
G.INP Framing:          0               0
G.INP lookback:         0               0
RRC bits:               0               0
                        Counters
                        Bearer 0
OHF:            0               923195
OHFErr:         0               173
RS:             254364832               4078301
RSCorr:         38632           179
RSUnCorr:       0               0
                        Bearer 1
OHF:            514739          0
OHFErr:         0               0
RS:             3088063         0
RSCorr:         6               0
RSUnCorr:       0               0
                        Retransmit Counters
rtx_tx:         605268          0
rtx_c:          3697            0
rtx_uc:         0               0
                        G.INP Counters
LEFTRS:         2               0
minEFTR:        40000           0
errFreeBits:    5043081         0
                        Bearer 0
HEC:            0               0
OCD:            0               0
LCD:            0               0
Total Cells:    618955334               0
Data Cells:     10994573                0
Drop Cells:     0
Bit Errors:     0               0
                        Bearer 1
HEC:            0               0
OCD:            0               0
LCD:            0               0
Total Cells:    0               0
Data Cells:     0               0
Drop Cells:     0
Bit Errors:     0               0
ES:             0               67
SES:            0               0
UAS:            26              26
AS:             8269
                        Bearer 0
INP:            55.00           0.00
INPRein:        1.00            0.00
delay:          0               0
PER:            0.00            8.99
OR:             0.01            28.46
AgR:            40122.38        8096.05
                        Bearer 1
INP:            2.50            0.00
INPRein:        2.50            0.00
delay:          0               0
PER:            16.06           0.01
OR:             47.81           0.01
AgR:            47.81   0.01
Bitswap:        6584/6584               138/138
Total time = 2 hours 18 min 15 sec
FEC:            38632           179
CRC:            0               173
ES:             0               67
SES:            0               0
UAS:            26              26
LOS:            0               0
LOF:            0               0
LOM:            0               0
Latest 15 minutes time = 3 min 15 sec
FEC:            899             0
CRC:            0               1
ES:             0               1
SES:            0               0
UAS:            0               0
LOS:            0               0
LOF:            0               0
LOM:            0               0
Previous 15 minutes time = 15 min 0 sec
FEC:            13537           2
CRC:            0               4
ES:             0               2
SES:            0               0
UAS:            0               0
LOS:            0               0
LOF:            0               0
LOM:            0               0
Latest 1 day time = 2 hours 18 min 15 sec
FEC:            38632           179
CRC:            0               173
ES:             0               67
SES:            0               0
UAS:            26              26
LOS:            0               0
LOF:            0               0
LOM:            0               0
Previous 1 day time = 0 sec
FEC:            0               0
CRC:            0               0
ES:             0               0
SES:            0               0
UAS:            0               0
LOS:            0               0
LOF:            0               0
LOM:            0               0
Since Link time = 2 hours 17 min 49 sec
FEC:            38632           179
CRC:            0               173
ES:             0               67
SES:            0               0
UAS:            0               0
LOS:            0               0
LOF:            0               0
LOM:            0               0
Moderator's note by Adie (Dvorak): Full quote of preceding post removed as per the forum rules
RealAleMadrid
Aspiring Hero
Fixes: 59
Re: speed cap
@carl0s You are on a 40/10 connection, you are at the full sync speed and moving to fibre extra will not get you much above 40 Mbps. You are actually getting just about the best speed you can. The IP profile is always less than your sync speed and the maximum throughput is always a bit lower than that because of internet protocol overheads. The only thing I can see that is reducing your throughput by a few percent is that you are on retransmission high, that is the highest level of G.Inp error correction but it is not easy to change that as it is all set by the automatic DLM system. Plusnet have no control of that.
In summary you are getting as good as it gets😀
notmyname
Re: speed cap
On reflection, there are quite a few errors on the line according to the stats you have posted. Might be worth an SFVA to get that looked into.
