something doesn't add up....
- something doesn't add up....
22-04-2017 6:05 PM
I've had countless engineer visits loads of other stuff but my problem is becoming a major headache
my connection drops enough to [-Censored-] me right off....
check my router it's connected at 61/19 which should be reasonable enough...
I keep lagging in D3 so I run a quick line test..... 1.60meg down 6.22up what am I paying you for.... seriously.
Message 1 of 2
(545 Views)
1 REPLY 1
Re: something doesn't add up....
24-04-2017 1:05 PM
Thanks for getting in touch, I've checked your fault and can see you've advised it's resolved so I've sent the fault ticket back to you.
Message 2 of 2
(429 Views)
