sluggish atm 19th june
- Full Fibre
- sluggish atm 19th june
19-06-2021 6:45 PM
Everything is loading slowly, youtube/twitch/google, some pages its like I am on dialup with images and icons taking 15+ seconds to load which should be nearly instant
Tried with both Opera and Waterfox on same sites with same issue. Did a clean reboot to see if it helped, a bit but not by much still sluggish
Re: sluggish atm 19th june
19-06-2021 8:30 PM
@Gus A little bit of information from you might help us here. What are the results of: (a)https://speedtest.btwholesale.com/ please report the results of the 'Additional diagnostics' (b) https://www.broadbandchecker.btwholesale.com/#/ADSL - obscuring your phone number and (c)-assuming you are using a PN Hub1 - the 'Help' page found under the Troubleshooting tab - again obscuring/deleting any personal details?
20-06-2021 3:43 PM - edited 20-06-2021 3:45 PM
Hi @Gus, thanks a lot for reaching out. There are a couple of abnormalities shown on my tests this afternoon, however as @jab1 has mentioned, further information would be helpful from yourself. Especially given that webpages are taking 15+ seconds to load!
Are you experiencing this through wired or wireless connections?
What have you done to troubleshoot your connection?
have you run a wired speed test on your end and if so, what results have you seen?
first of all, I've sent out an upgraded router to your property, (Plusnet Hub One) given the fact that you've had yours for over 6 years now. This should improve your wireless connection, however as I said, there does appear to be an issue or two on the line itself which may need investigating further. While the estimated speeds on your line are between 49 - 70Mbps, you were achieving speeds of around 66.9Mbps over the last few days, however this has dropped back down to 52Mbps, which seems quite odd.
The line is also banded up to 67Mbps, though your DL sync speed as mentioned, is 52Mbps, which indicates a possible fault on the line.
Going forward, I'd ask that you remove the face plate of your master socket, and connect directly to the test socket which lies behind it. Leave it in there for a couple of days and run a wired speed test to see how you're getting on. If the issues persist, please head over to faults.plus.net, and raise the issue with our Technical Support Team.
20-06-2021 6:32 PM
it cleared up later that night, recently BT have been been putting in ducting for FTTP down my street, I am guessing its fallout for that as no rice crisps on my land line and normal router stats.
FYI @adam945 I have a better router so no need but after talking to support after not seeing your reply after getting the email about the hub one being delivered, I never requested it. I will be refusing delivery so it will be back in a week or so, if damaged then its on the courier.
20-06-2021 6:56 PM
@Gus Nice one😀 I would never let a Hub1 cross the threshold. I have never used ISP supplied routers, they are usually cheap and nasty. I use a Lancom enterprise grade router and Wi-Fi access points. Totally configurable and excellent monitoring software.
20-06-2021 8:03 PM
Using a Billion 8800NL has been rock solid for years now
04-07-2021 5:53 AM
@adam945 the router never arrived, so unless you stopped the delivery and it was returned. You need to chase up with the courier as its missing if not.
05-07-2021 11:18 AM
No problem @Gus
I've only just come across this post, the router does appear to have been dispatched on 22/06/2021 so I'm unsure as to why it hasn't arrived, I wouldn't worry about it if you're not using it anyway.
How have you been getting on with the download speeds? further tests on the line this morning have found it to be operating within an estimated range, I'm seeing download speeds of around 52.6Mbps. Something which I overlooked last time though, DLM has turned on a low level on interleaving on the line. This preserves stability but does decrease your download speeds slightly.
Saying that, websites should not be taking 15+ seconds to load so if you've tested your wireless connection through your 3rd party router and are adamant that the issue is with the line itself, please let us know and we'll be happy to raise this with Openreach. As there are no underlying faults with the network though, it'd be likely that we'd need to arrange an engineer appointment. Have you managed to run any wired speed tests yet? If so, what speeds are you getting?
