slowing Fibre Broadband NEW Customer
FIXED- Subscribe to RSS Feed
- Re: slowing Fibre Broadband NEW Customer
02-05-2016 9:20 PM
Hi all 9pm and speed just dropped off again this time ,now on BT wholesale 42.84 down and 10.3 upload 39.76 down and 12.56 upload on Plusnet Tester at 9.10 31.76 and 13,00 and 44.75 and 12.64 , i wounder if that is low enough for Plusnet to Log a Fault , Not impressed with this erratic service
02-05-2016 9:28 PM
Hi
speed dropped off to 42.84 and 10,30 on BT 9pm Wholesale Tester and 39.76 down & 12.56 up at 9.05pm on Plusnet Tester 31.28 and 13.00 at 9.10 44.75 down and 12.64 upload what poor erratic service , is this enough to log a Fault , it is only up to the 40s at 9.30pm or does Plusnet call this a Blip very angry
02-05-2016 10:41 PM
Still no sign of any router stats.
Speed tests vary depending on who you use, just imagine if everyone else tests at the same time as you. Even more so via WiFi, what device are you testing from? Is it capable of reliable speeds?
Have you considered using DSLstats, or Samknows, or something with more information that can help with any diagnosis, or do you just have a gripe with PlusNet?
03-05-2016 2:29 AM
Have you tried the gateway hop solution? But given the times it sounds like possibly congestion.
Gateway hop, login to router click disconnect and wait 30 minutes and then click connect and see if it makes any difference. Worth a shot
If you Like it, give it a
03-05-2016 7:01 AM
I think your last comment was a bit personal
03-05-2016 7:45 AM
using recommended Plusnet testers OKALA ,Plusnet OWN Tester and BT Wholesale Tester I do not think 9pm is classed as peak time and connected with Ethernet cable not Wi Fi , after Plusnets sale pitch expected more
03-05-2016 7:52 AM
If you Google something like 'Broadband speeds slower at peak times UK?' you will find that 9pm is very much within the evening peak range for internet use in the UK, although the average slow down varies quite a bit from area to area.
03-05-2016 8:07 AM
Hi thanks for your response
I do think that a drop of from 62 mb to 53mb in less than a week and then another drop of 20+ mb to 31mb last night is a bit much ,while on BT i never had anything like this even at peak times Bank Holidays , i only left BT because of their overseas customer service center at the moment this is the poorest service i have had and did not expect
03-05-2016 8:09 AM
NO IT IS NOT FIXED
03-05-2016 9:04 AM - edited 03-05-2016 9:07 AM
This very much sounds like either a gateway issue or congestion. What speeds does router say you're connected at?
Also can you visit https://portal.plus.net/my.html?action=data_transfer_speed and tell us current line speed.
03-05-2016 9:14 AM
53.07 download and 13.10 upload 2nd test 52.17 and 12.80 ist test bt wholesale 2nd test okala .
1st 10 days of connection 62meg and very stable came back friday from a 2 day break and down to 53/54 meg just above mimimum strange that i should have an 8meg drop on a stable line in such a short time
03-05-2016 9:19 AM
hi
I am over wire have been connected via ethernert cable from the start
03-05-2016 9:20 AM
03-05-2016 9:22 AM
now have problem with telephone keeps saying line in use so cannot contact anybody, no more tests this morning Hospital visit
05-07-2016 9:31 AM
Hi, just thought i'd add my experience to the thread...
Was on ADSL for a couple of years with Plusnet and upgraded to FTTC a couple of months ago, speeds are maximum 21mb download but this regularly drops to below 1Mb - Had 2 BT engineers out who changed the master socket, they mentioned the copper wire from the pole could be the issue but see how it goes, 2nd BT engineer couldn't understand fluctuation of speeds, said new master socket was also faulty and replaced it. I bought a new laptop as the engineer thought it could be that, he also said the router might need replacing and he would request this from Plusnet (but a replacement never arrived) he also said Plusnet can cap speeds and there may be something not right their end. Anyway, after forking out for a new laptop, losing my extension in the kitchen (because apparently Fibre doesn't like internal extensions) I am still no better off, I just keep monitoring the speed and reporting the issues but it's becoming very tedious and time consuming, I just wanted a decent stable speed!!!
The most recent update 3rd July was as follows:
As per my message, I am sorry to hear that you've been experiencing issues with the speed of your connection. I have tested your line and it appears the speed issue may be due to some incorrect settings on the account. I have altered these and we would now expect the line to be running at full speed. If you are still experiencing issues and have tried a reboot of the router please get back in touch so we can investigate further.
