slow upload
ad47uk
slow upload
Download is great, I get a good 38ish Mb/s, but up load is anything between 2-5, I did get ten for a while.
While it is not that important at the moment, I went fibre more for upload speed and yet I find it is not much better.
Re: slow upload
Can you post the result of http://speedtest.btwholesale.com/ (Further Diagnostics) please?
This will provide some useful information about IP profiles and confirm speeds.
Call me 'w23'
Fixes: 136
Re: slow upload
Your current upload sync is 0.3mbps which does seem to indicate a issue
I'd recommend raising a fault using the link below
https://faults.plus.net
 Matthew Wheeler
