slow speeds
trekrich
slow speeds
Anyone find their speeds are really slow tonight?! I normally get at least double that!
Fixes: 414
Re: slow speeds
Sorry to hear you're experiencing speed problems.
Line tests are showing your router in sync at a downstream rate of 72.1mbps
A high upload speed and low download is usually indicative of a WiFi issue.
Are you testing via a wireless or wired connection?
trekrich
Re: slow speeds
that was done on wired. But i have left a test running all day, and it seems fine now. I will leave it testing and come back to this thread if it goes weird again. Thanks!
Fixes: 414
Re: slow speeds
No worries. Let us know if you need further assistance.
