slow speed
- slow speed
slow speed
14-09-2019 11:41 PM - edited 14-09-2019 11:54 PM
my sync speed is at 69mbps but I only get 54mbps. I have had Openreach out but they have not been able to fix it(3 lift and shifts on the port and used a spare line coming to our block of flats). is there any reason that there is a 20% difference in speeds. also our guaranteed minimum download speed is 67mbps. (not sync speed because of the new Ofcom regs that Plusnet signed up to). any help in getting this sorted would be much appreciated. when we first moved in we were getting 75mbps download speeds and has dropped over the last 5 months
edit(speed is 15mbps lower on Plusnet hub one and unifi enterprise equipment and has actually dropped by 2mbps since the engineer has visited.)
thanks
Re: slow speed
15-09-2019 12:30 AM
from my broadband page
Re: slow speed
15-09-2019 5:34 PM
Hi @louiswood,
I'm sorry to hear that you're experiencing this issue. I've responded to you on another thread on here just a few minutes ago, but going forward using this thread would be best for discussing your fault. I've checked your account and can see that this is already being looked into as a fault and that the last update was on Friday, essentially advising that we'd sent the case back to our suppliers and were awaiting a further update. Upon retesting your line, I can see that the speed is currently syncing at 60.9Mbps download speed, which is just within your estimates. Before we go any further at this stage, I'd ask if this is the case for your throughput speeds when testing the speed in the property whilst the router is connected to the test socket and the test is being done on a device connected via Ethernet cable to the router?
Re: slow speed
15-09-2019 6:30 PM
Re: slow speed
15-09-2019 10:15 PM
can i see the gea that is saying my speed is at 60.9 please and what is a kbd test? as aparently one of them has been ran and is showing a fault. if io could see both that would be great.
Re: slow speed
16-09-2019 11:23 AM
Hi @louiswood
I've provided the info you've requested on your open fault ticket here.
Unfortunately, despite the stability of your line improving, the speed of your account is still lower than we'd expect after the additional external work. Therefore it is likely that a subsequent engineer to your property would be required.
If you'd like to arrange this, please provide your availability via the ticket I've linked and we'll get that booked in for you.
Best wishes
Dave
