slow/intermittent connections
- slow/intermittent connections
02-11-2016 8:18 PM - edited 03-11-2016 2:43 AM
Since the 25th of October my speeds have been extremely slow, I've also noticed a massive reduction in download speeds. A 161mb file took me 45 minutes to download - sometimes getting a stable connection is impossible. The range of the wifi itself has been abysmal, if I'm not sat in the same room as the router I get no internet whatsoever. I've never had issues with plusnet before, everything has been fine up until a few days ago. I checked all the planned work and none seemed to affect anywhere close to me.
Ran a speed test, the results are as follows:
download: 0.7Mb
upload: 0.23Mb
Ping Latency: 205.00
Re: slow/intermittent connections
03-11-2016 12:14 PM
Hi, given what you've mentioned and what I can see noted from a call to us yesterday it really does sound like a WiFi issue.
Can you give the tips a try we listed on ticket 137299737 please?
You might also find the information here useful: https://www.plus.net/help/broadband/getting-the-best-wifi-signal/
03-11-2016 5:00 PM
I've done all of this and it's not helped whatsoever.
