slow/intermittent connections
smtt20211
Since the 25th of October my speeds have been extremely slow, I've also noticed a massive reduction in download speeds. A 161mb file took me 45 minutes to download - sometimes getting a stable connection is impossible. The range of the wifi itself has been abysmal, if I'm not sat in the same room as the router I get no internet whatsoever. I've never had issues with plusnet before, everything has been fine up until a few days ago. I checked all the planned work and none seemed to affect anywhere close to me.
Ran a speed test, the results are as follows:
download: 0.7Mb
upload: 0.23Mb
Ping Latency: 205.00
2 REPLIES 2
adamwalker
Fixes: 221
Re: slow/intermittent connections
Hi, given what you've mentioned and what I can see noted from a call to us yesterday it really does sound like a WiFi issue.
Can you give the tips a try we listed on ticket 137299737 please?
You might also find the information here useful: https://www.plus.net/help/broadband/getting-the-best-wifi-signal/
 Adam Walker
smtt20211
I've done all of this and it's not helped whatsoever.
