slow fibre speeds
- slow fibre speeds
- « Previous
- 1
- 2
- Next »
Re: slow fibre speeds
20-12-2017 7:58 AM
done test this morn at 7.45
https://www.thinkbroadband.com/_assets/speedtest/button/1513755925355491655.png
so must have something bugging me at night as websites take awhile to load aswell
even this morn sites not loading fast but a lot faster than last night
20-12-2017 10:04 AM - edited 20-12-2017 1:08 PM
Speed test reported 34 mbps on Ethernet media player and 32mbps on 2.5Ghz WiFi mobile.
However this morning media player is down to 2.6mbps with 471ms latency, quiet phone line test was ok.
22-12-2017 5:16 PM
We use cookies to make sure you have the best experience on our website. By continuing without changing your settings, you agree to receive all cookies. Read our cookie policy for more information.
Oops, something seems to have gone wrong
It looks like something has gone wrong. Our award-winning support team are here to help.
22-12-2017 5:25 PM
now have new filter at master socket but so far not a lot of difference
web pages taking their time at loading as well
some speed test are ok and some are rubbish at different times of the day
might be an intermittent fault ?
26-12-2017 2:25 PM
Sorry to hear the problems are continuing.
Our tests aren't showing any issues still and from your speed tests your speed is on target.
Are your devices connected to the router over WiFi or using an ethernet cable?
26-12-2017 8:56 PM - edited 26-12-2017 9:05 PM
Hi Gandalf
normally use ethernet cable for speed tests not that it makes much difference as get the same speed over WiFi.
have updated the firmware on the router aswell as putting new filter in master socket
to day the speeds seam more stable
https://www.thinkbroadband.com/speedtest/1514321179442565855
27-12-2017 3:20 PM
When your speed is particularly slow, can you run a BT speedtest at http://www.speedtest.btwholesale.com, completing the further diagnostics at the end? This will store the result on the supplier system and will help us in reporting a fault.
28-12-2017 6:38 PM
Hi Gandalf
will do a BT speed test if start having problems again
28-12-2017 7:33 PM
- « Previous
- 1
- 2
- Next »
