slow fibre speeds
brettmessruther
slow fibre speeds
-not using wifi
-bt speedtest  attached
video guide followed.
basically my connection has dropped from what used to connect at roughly 55Mb to 40 Mb or less and download speeds have dropped from 6.8 MB/s to 5.1MB/s this has only happened in the past week at most as i have seen speeds at max while downloading steam games in the short time before this.
attached 3 files that should help
Moderator's note by Mike (Mav): Personal information removed from attachments in a public forum.
mikelahey
Fixes: 10
Re: slow fibre speeds
As you are getting well below the estimates in the BT wholesale line checker, you should raise a fault with Plusnet.
Perhaps @Gandalf or one of the other Plusnet staff could take a look at this for you.
brettmessruther
was not sure if i should do that or wait for them to see it here and look into it!
Fixes: 219
I can see you've raised a fault regarding this.
We'll get that picked up as soon as possible.
 Matthew Wheeler
brettmessruther
is there anywhere i can look to track the progress of this?
