slow fibre speeds
goatty2
slow fibre speeds
anyone having slower speeds this afternoon?
mine has gone from 38 a couple of weeks ago to 32 and today :-
https://www.thinkbroadband.com/speedtest/1513522425822123955
speed all over the place
23 REPLIES 23
gleneagles
Aspiring Legend
Fixes: 17
Re: slow fibre speeds
My speeds tend to alter within that range, not really a problem for me.
I suspect the time of day along with various other factors cause this.
More important for me is a stable connection with no drop outs rather than changes in speed.
If it dropped much below 30 then of course I would be concerned
We are born into history and history is born into us.
Sturgi
I would be happy to get close to 30 so far since joining on Unlimited Fibre the fastest I have had is 18.2 with the slowest 5.7, wish I had never left BT.......
goatty2
did a bt test
1. Best Effort Test: -provides background information.
  Download Speed
  33.97 Mbps
0 Mbps 33.85 Mbps
Max Achievable Speed
 Download speedachieved during the test was - 33.97 Mbps
 For your connection, the acceptable range of speedsis 20 Mbps-33.85 Mbps .
 Additional Information:
 IP Profile for your line is - 33.85 Mbps
  Upload Speed
  3.4 Mbps
0 Mbps 10 Mbps
Upload speed achieved during the test was - 3.4Mbps
 Upstream Rate IP profile on your line is - 10 Mbps
did another thinkbroadband test
https://www.thinkbroadband.com/_assets/speedtest/button/1513538905644647255.png
just wondering if there is a fault with their tester
Mustrum
Fixes: 77
What is your phone like? Is it quiet if you dial 17070 option 2?
It looks like DLM has reduced your speeds, possibly due to a noisy line.
goatty2
just done quiet line using an old phone
would not say it was quiet sounds a bit fussy
Mustrum
Fixes: 77
It will be worth going through the checks as described in the Help section here.
goatty2
just ran the line test and got :-
Oops, something seems to have gone wrong
It looks like something has gone wrong. Our award-winning support team are here to help.
Call us on 0800 432 0200
but 30 min wait so i'll call them in morning
Moderator's note by Mike (Mav): Post released from Spam Filter.
Manny7860
@gleneagles I've read plusnet stopped doing traffic management on their lines?
Excellent!
goatty2
phoned them this morn and something wrong and they said it could be the filter in the master socket which bt installed when i went over to fibre a few years ago .
so ordered a new one
might get it this week hopefully
Fixes: 1,600
I'm sorry to hear you're experiencing speed problems
Testing your line is showing your router in sync at 35mbps. Whilst it is banded at that:
Profile Name 0.128M-35M Downstream, Interleaving Low - 0.128M-10M Upstream, Error Protection Off
as the speed is within your estimates there isn't much we can do to further investigate.
If your speeds drop below the estimates I'd raise a fault to us at http://faults.plus.net
goatty2
goatty2
just done speedtest on speedtest.net and got this
http://www.speedtest.net/result/6894378816.png
 and now the new test:-
 http://www.speedtest.net/my-result/6894420102
Manny7860
404 not found.
Excellent!
goatty2
great was working before now it not am having a good night
