slow fibre speed for last week or so in evenings
- Re: slow fibre speed for last week or so in evenin...
05-01-2015 7:30 PM
Have been having issues with my fibre speed being really slow in the evening for probably the last week or so.I have to reset my router and then the speed seems to return to normal and stays there.Is it worth raising a fault on it or could one of the plusnet team members have a look at my line stats?
thanks
chris
This is my speed after reseting
<a href="http://www.speedtest.net/my-result/4035960805"><img src="http://www.speedtest.net/result/4035960805.png" /></a>
Re: slow fibre speed for last week or so in evenings
05-01-2015 8:05 PM
<a href="http://www.speedtest.net/my-result/4036038823"><img src="http://www.speedtest.net/result/4036038823.png" /></a>
the speeds seem very erratic
chris
06-01-2015 8:56 AM
06-01-2015 6:47 PM
Many Thanks
Chris
06-01-2015 8:31 PM
07-01-2015 9:01 AM
07-01-2015 10:30 AM
11-01-2015 9:09 PM
I seemed to have closed the ticket that I raised on my line.just wondered if it may be reopened again.still having the same problems
thanks
chris
12-01-2015 8:53 AM
As opposed to this from a month ago:
and this morning is good:
Note that all tests are performed using an Ethernet connection.
I'm connected via pcl-bng04.
I think my line is good. There's never anything much on my TBBQM (aside from a couple of brief packet loss spikes last week that I think are common to most PN connections).
12-01-2015 9:16 AM
However there does seem to be a definite change in 2015...
I'm in northampton on the Hardingstone exchange if that has any relevance.
12-01-2015 8:29 PM
Single thread hanging around 20Mb/s, multi-thread runs at full speed over three times as fast. That reminds me of a problem I had with IDNet a couple of years ago that turned out to be a mis-configured router at their end.
12-01-2015 9:18 PM
12-01-2015 9:22 PM
12-01-2015 9:26 PM
12-01-2015 9:28 PM
