signed up for higher end fibre but getting low results
claire111
hello everyone, I have joined plusnet today and my broadband speed test is around 25-28 mb
I was told when ordered I can get speeds at high end up to 76mb,
would this just be a temp problem with b/band just settling down or does it sound like a faultHuh
Fixes: 239
Re: signed up for higher end fibre but getting low results
Sorry to hear you're having issues with your download speeds.
Are you testing over a wired or wireless connection?
 Matthew Wheeler
claire111
wireless to laptop,tested on Ethernet and average same result
Have you run a BT speedtest (both parts of it)?
Fixes: 239
Our tests are showing what's known as a bridge tap which could be a internal issue.
Can you confirm the router is connected to the master phone socket?
 Matthew Wheeler
