several wifi cams etc. with TG582n router
- several wifi cams etc. with TG582n router
07-11-2014 3:44 PM
i have the standard TG582n plusnet router and have been unable to connect more than a few camera's and printers to it . wired connections are no problem. i have just removed all encryption from the router and am now able to connect to all 4 cameras and a couple of printers, and a laptop with no problems....
Is this a function of the encryption s/w or a cheap router...
i am not that happy about my network being unsecured. but it seems to be the only way to get everything connected.
any advice welcomed....
Message 1 of 4
(706 Views)
3 REPLIES 3
Re: several wifi cams etc. with TG582n router
08-11-2014 4:49 PM
Sorry to hear about the problem you've mentioned.
We'd not describe the TG582n as an advanced router but you shouldn't be having any issues trying to achieve what you've mentioned.
I'll have a chat with our products team on Monday and see if we're able to offer you any advice on that
Message 2 of 4
(374 Views)
08-11-2014 5:23 PM
I think you will find that the problem will be that the cameras don't have the capability to handle the length of password or the security level of the router
But you don't want to reduce the security of your WiFi to suit the cameras
To do is to be - Neitzsche
To be is to do - Kant
do be do be do - Sinatra
Message 3 of 4
(374 Views)
08-11-2014 8:04 PM
One thing you could do is get a 2nd known-brand router that is used solely for the cameras, piggyback off the primary router and set the 2nd router to take it's DHCP settings from the primary router, but having it's own wifi key to connect the cameras and isolated (turn off the SSID Broadcasting once the cams are connected to prevent unwanted access) solely for their use ...
Message 4 of 4
(374 Views)
