self install fibre question for plusnet staff
cagerty
Hi
I want to upgrade my ADSL package to fibre broadband and as I understand it I will be getting a Hub One so I assumed it would be self install. However on the upgrade screen it still asks me for an engineer appointment. I am self employed so can't really afford to take a day off work to wait for an engineer. Is it possible I could self install and cancel the engineer?
dick:green Superfluous quote tags removed.
Fixes: 78
Re: self install fibre question
Hi cagerty,
I can make sure that's a self install for you.
Please go ahead with the upgrade request along with an appointment then drop me a reply or a PM here and I'll pick up the order.
 Adam Walker
cagerty
Re: self install fibre question for plusnet staff
Thanks, I have now completed the upgrade. Could you confirm the engineer has been cancelled and my completion date?
Also I seem to be getting sent a plusnet 2704n router. Shouldn't I be sent a hub one for a self install?
Cheers
cagerty
Hello
Could someone from plusnet please confirm that my self install order has been put though and that I am being sent the correct router. Adam sent me a pm advising he would pass this to a colleague to action. I was also advised the engineer appointment would be cancelled.
Fixes: 205
Unfortunately automation has put it through with an appointment.
Leave this with me and I'll sort it out and send you an update via a ticket on your account within the next 24 hours once I'm able to get a self install order in place for you.
 Harry Beesley
cagerty
OK thanks
cagerty
Thanks for sorting my order Harry. Can I confirm this is a self install and that the previous engineer appointment was cancelled? Can I also confirm that the evening and weekends phone product is still on my account as per my original fibre order? Thanks.
Fixes: 205
I haven't changed anything that you had set up on your account so the account change will be exactly how it was initially set up.
I simply cancelled the order on our suppliers systems and placed a new order that was self install Wink
 Harry Beesley
cagerty
Lovely, thanks.
