router
- router
router
27-01-2015 1:41 PM
Re: router
27-01-2015 1:44 PM
Re: router
27-01-2015 1:48 PM
dvorak is 100% correct.
The modem will be coming out with the engineer.
However, the router is sent and I will check now to see if its on its way to you.
Re: router
27-01-2015 1:50 PM
Re: router
27-01-2015 1:54 PM
Re: router
27-01-2015 1:55 PM
Re: router
27-01-2015 2:02 PM
Re: router
27-01-2015 2:07 PM
@patti
Again dvorak is correct, thanks
Just an update I have sent a router to you today, our latest version too
It takes 3 to 5 working days
Re: router
27-01-2015 2:09 PM
Re: router
27-01-2015 2:11 PM
Re: router
28-01-2015 12:31 PM
Re: router
28-01-2015 12:33 PM
Re: router
28-01-2015 12:34 PM
Quote from: MisterW Nope, it's 100Mb only.
Damn - looks like I'll be sticking with my current router 😕
Re: router
28-01-2015 1:06 PM
Re: router
28-01-2015 1:09 PM
Quote from: taras your current router needs to able to do PPPoE
Would the homehub 5 be capable of this and is it easy to configure to use the PN fibre broadband?
My current set up is HH5 (wifi off) using the ethernet ports on the HH5 to create a gigabit network, with 1 ethernet port on the HH5 connected to an Apple Time Capsule to create a wifi network with that - complicated I know but the wifi is better for the various things connected to it.
Any advice would be useful.
Cheers.
