router security after ransomware attack
- router security after ransomware attack
- « Previous
- 1
- 2
- Next »
Re: router security after ransomware attack
27-09-2019 1:03 PM
27-09-2019 1:07 PM
27-09-2019 1:10 PM
will this restore it to how it was when I received it ie with login details already in place or will I need to manually enter some stuff?
27-09-2019 1:12 PM
27-09-2019 1:21 PM
Yeah a reset has been advised by our products team 👌
@Baldrick1 - each to their own, at the end of the days it's down to preference really
Thanks,
MoR
27-09-2019 1:48 PM
@@whatsisname22 - resetting the router shouldn't make the auth credentials fall away, if it does then its just your username+@plusdsl.net and your password to force it back online.
Thanks,
MoR
27-09-2019 2:09 PM
@whatsisname22 wrote:
... I didn't even know that firewall was there. so that's at the plusnet servers end, blocking traffic before it even gets to my router?
Yes, it blocks unsolicited attempts from external sources from ever reaching your router.
You can test whether any router service ports are visible externally by running a port scan test.
I tend to use GRC ShieldsUP! to check my system.
Go to the GRC website - https://www.grc.com/
Select "ShieldsUP!" from the drop down [Services] tab.
Click on the [Proceed] button
Click on the [All Service Ports] button (near the centre of the page)
Let the test run for about 70 seconds
Then read what the recommendations are if you don't get a perfect result like this -
27-09-2019 3:05 PM
with regards the phobos virus itself, does anyone know whether it can compromise the actual MBR of the hard disk that the infected OS is on? or can it only infiltrate the OS?
I am about to restore a safe acronis backup image of the system partition but that doesn't necessarily replace the MBR I think? the MBR exists outside the OS partition right?
27-09-2019 3:29 PM
- « Previous
- 1
- 2
- Next »
