[resolved] Fibre Extra speed fault
- [resolved] Fibre Extra speed fault
27-12-2015 8:30 AM
Good morning,
I was just wondering if someone could be of help, my connection speed is much lower than expected during a non peak time. My connection when installed would give me about 50 Mbps down and 19 Mbps up, however when a day passed the connection speed dropped quite signifigantly.
Now according to the plusnet line checker something is wrong,
https://drive.google.com/file/d/0BxlTQjnkUieAemlkbC05TTB5NEk/view?usp=drivesdk
I've even ran speed tests which confirm their is an issue:
https://drive.google.com/file/d/0BxlTQjnkUieAM19ZaWRCSmplYms/view?usp=drivesdk
And I checked my IP Profile, like told to:
https://drive.google.com/file/d/0BxlTQjnkUieAOEdKc2JiRUtmcFU/view?usp=drivesdk
These results were collected using my test port for the best accuracy. The results remain the same using another VDSL router with G.vectoring. My distance from the exchange is very minimal literally about 500 meters away. My line is clear when a phone is plugged into it.
I've also just executed these tests on two seperate computers using different ethernet leads, the results were not extremely different.
Has anyone got any clues as to what is wrong with my connection?
Thanks!
Thanks!
Message 1 of 4
(1,065 Views)
3 REPLIES 3
Re: Fibre Extra speed fault
27-12-2015 10:27 AM
For some reason the Plusnet profile is wrong - either use chat or phone to get it fixed
One possibility is that it has dropped back to the ADSL value
Message 2 of 4
(500 Views)
27-12-2015 12:20 PM
In the process of doing so, been on the phone for about 50 minutes listening to call center music.
Message 3 of 4
(500 Views)
27-12-2015 12:51 PM
Quote from: Oldjim For some reason the Plusnet profile is wrong - either use chat or phone to get it fixed
Thank you for your help, all working now
Now, back to programming.
Message 4 of 4
(500 Views)
