replacing plusnet TG582N with netgear R6300
- Re: replacing plusnet TG582N with netgear R630...
18-02-2015 5:29 PM
i want to replace the supplied technicolour router with the netgear.
this will involve plugging the netgear WAN port into the supplied LAN port.
i would like to know the settings to punch into the netgear first rather than trial and error!
many thanks
many thanks
Message 1 of 4
(738 Views)
3 REPLIES 3
Re: replacing plusnet TG582N with netgear R6300
18-02-2015 5:40 PM
Good evening,
The DSL username would be your Plunset username you first signed up with.
username@plusdsl.net
Your password is the one you also use when you first signed up.
Message 2 of 4
(447 Views)
18-02-2015 5:53 PM
i think the user name would depend on the network you signed up with.... in my case F9
also should the WAN not be set to PPOE?
i suspect a little more involved than just log in info since you are connecting to the BT openreach FTTC modem
Message 3 of 4
(447 Views)
18-02-2015 5:57 PM
Message 4 of 4
(447 Views)
