remote access issue
duncan320
remote access issue
Hi All
I have a TG582n router, and I have a number of CCTV cameras I need to access, I use dyndns.org on the router and NAT to get to them on my previous ISP's but the Plus net router is nothing like any other ISP router I have seen, so different.
So say from my phone CCTV app I connect to myname.dyndns.org:81  (etc) ..... and this translates on the router to 192.168.1.50:81 but I cant get it to work with any of my camera's on this router
I have followed guides such as this http://portforward.com/english/routers/port_forwarding/Technicolor/TG582n-O2_Technicolor/Cobra_Elite... (even though different ISP same options) no luck, any ideas ?  The ports dont show as been open on port scan either.
Any ideas ?
I called plus net support the guy was helpful but said its not something they support.  I asked about this when I ordered and was told it would work.
itsme
Re: remote access issue
Have you check Plusnet Firewall?
Login to the Members centre, select connections settings, then select Broadband Firewall.
duncan320
Firewall shows as been "Off"
Fixes: 167
Does this post help at all?
http://community.plus.net/forum/index.php/topic,113303.msg1170658.html#msg1170658
 Chris Parr
 Plusnet Staff
duncan320
Yes thats great, managed to get them all working now, looks like i was doing similar to the other person Smiley
Fixes: 167
Great news, thanks for getting back to let us know.
 Chris Parr
 Plusnet Staff
