ref: samknows testing and netflix
Ok I know why now I have no netflix testing, those who dont have the test enabled are using old legacy units, after a new query they sending out a new one to me.
Just to let other testers know.
Fixes: 4
Re: ref: smaknows testing and netflix
You are aware that you will loose all previous data though ?
Re: ref: samknows testing and netflix
no, but some of my existing graphs have also stopped working, they said they cant be fixed without the new device.
Fixes: 4
What they sending out a WDR3600 ?
I keep loosing iplayer tests on this box, last time I had to give them access to have a look at the problem, but my recent loss of iplayer tests just automagically started working again.
Edit: Added screeny of down time, about a month I think!
no idea what device it is until I get it. I dont even have iplayer tests.
basically all I got working now is speed and ping tests.
web page loading time and dns tests are all blank, no streaming tests at all.
Fixes: 4
Is your DHCP server assigning plusnet dns to the sam box ?
I cant verify as I have no access to the samknows box but I can report it configures dns fine to all my other devices.
sorry misread your question, no I dont use plusnet dns on my network.
Fixes: 4
I would try setting up another pool with 212.159.6.9/212.159.6.10 just for the Sam box and force it to use it (Easy for me 'cus my network is all static apart from the Sam box.), I recall something funny about the dns... my box would not register without plusnet dns being assigned. Might be worth a try just for the hell of it.
St3
All Star
Fixes: 4
i just stopped using netflix ... no new movies for me to watch most are too old and ive seen a million times almost ;p
