reduced fibre speed
paulhanna63
reduced fibre speed
Has anyone experienced sudden drop in fibre service to less than half speed in the last 24 hours?
13 REPLIES 13
MatthewWheeler
Fixes: 480
Re: reduced fibre speed
There's no issues we're aware of.
Are the speeds still poor?
 Matthew Wheeler
paulhanna63
Yes still running half normal speed when I checked at 8.30am
Can the telephone exchange be checked?
MatthewWheeler
Fixes: 480
If you try a reboot of the router the speeds should go up.
 Matthew Wheeler
paulhanna63
Tried rebooting the router made no difference. How change the exchange be checked out?
MatthewWheeler
Fixes: 480
There isn't any issues with the exchange I can see so I'd recommend raising a fault here
 Matthew Wheeler
patti
Hi Paul, yes mine dropped by more than half yesterday evening and it's still running slow, been fine for a few weeks. I dont understand why this happens.. very erratic.
MatthewWheeler
Fixes: 480
@patti Have you gone through the steps at https://faults.plus.net ?
 Matthew Wheeler
patti
yes Matthew I have. This happens quite a lot. It's never been a stable connection, when I first changed to Fibre last 15 months ago it was great at first. I was told by the Engineer the speeds were capable of reaching 80 megs.. Was told I should expect 38 meg. Can you check my profile and ensure I am getting my correct speeds please?
MatthewWheeler
Fixes: 480
@patti You're on the old 40/20 package so if you wanted more speed you could upgrade to the Fibre Extra package.
The connection looks fine from what I can see.
Are you connecting over a wireless or a wired connection?
 Matthew Wheeler
paulhanna63
I checked both wireless and wired
its now back to normal 11mb
paulhanna63
Is fibre extra the pro add on for £5
Chris
Legend
Fixes: 169
No, the pro add-on and Fibre Extra are completely separate.
Fibre extra allows speeds up to 76Mbps.
paulhanna63
Line seems to have settled back on 10 mb
Extra would be of no benefit because service is not available as I am 3km away from exchange
