re-signed for fibre and assured speed would not change
- Re: re-signed for fibre and assured speed would n...
26-10-2015 7:14 PM
I have re-signed for fibre today for 2 years after calling regarding an incorrect end date on my current contract, I was offered to correct it to the 6 months remaining or resign on a very good deal which I accepted on the basis that
my package would not change in any way. IE 40/10 downgraded to 40/2. I'm not very trusting so I recorded the call.
I asked the question before agreeing and he went away and checked with somebody, He came back and I was assured it was simply re-signing and nothing would change, however when he finished the call with "if it does change you have 14 days cooling off" my concerns re-surfaced so here I am.
I'm not due to change until the 5th so have a few days yet to cancel and remain where I am if need be.
my current sync from drayek
Connected : Down Stream : 55424Kbps / Up Stream : 15836Kbps
while bt wholesale speed test gives me 38mb down and 13 up
Anybody else resigned and had there package changed or not as the case may be.
Glen
Re: re-signed for fibre and assured speed would not change
26-10-2015 7:30 PM
You were on 40/20 which was a BT Openreach 80/20 with the download capped by Plusnet to 40Mb/s
You are not alone there have been many reports of that happening
26-10-2015 7:35 PM
As Jim says, from those figures it's looks like you are on the old Fibre Unlimited 40/20 product. That is not a current product, the only current products are Fibre Unlimited Extra which is 80/20 and Fibre Unlimited which is 40/2. Hopefully one of the CRT team will see your post and confirm the situation but from other posts recently my guess is that if you have recontracted to Fibre Unlimited then it will be 40/2!
Quote my current sync from drayek
26-10-2015 7:58 PM
26-10-2015 10:15 PM
26-10-2015 10:49 PM
Clearly we need a definitive answer. I will try and look out my old post and provide a link for it.
Podman
26-10-2015 10:58 PM
Simple Straight forward Reply States there should be NO change: http://community.plus.net/forum/index.php/topic,141740.0.html
Podman
27-10-2015 9:51 AM
I shall post back when it happens at let you all know the outcome
Glen
27-10-2015 1:23 PM
27-10-2015 3:02 PM
27-10-2015 10:14 PM
I don't think I am in a place yet yet on my account where I am able to re negotiate but your's goes trough ok i may consider re-contracting.
podman
31-10-2015 12:54 PM
02-11-2015 9:50 AM
05-11-2015 10:37 PM
however on getting home and looking at router stats , I can confirm it would appear that nothing looks to have changed my end as Harry stated originally.
My speeds are down slightly on upstream however My router has been on and off a number of times on the 3rd and 4th as I have been re-routing my cabling in the house whilst having some electrical work done so Ill put that down
that.
Connected : Down Stream : 56696Kbps / Up Stream : 9168Kbps
