random slow tcp connections
bobpullen
Fixes: 316
Re: random slow tcp connections
@Browni, I think you might be looking at something else.
You're pulling 25mbps+ on a single thread, rather than the 2-3mbps others were been seeing. Possibly something congestion-related. Is it worse during the busier hours? i.e. 5pm-Midnight?
Terranova667
Fixes: 5
Hi Bob whilst it no longer starts off at 1-2Mb as before throughput is now struggling to hit the top end i'm seeing anything from 25-35Mb on a single thread even multi-thread is struggling it seems my connection was reliant on the links that were turned off any idea when thy will come back into play I would rather have the previous problem than the one I have now.
1515004126624056255-mini
Browni
Aspiring Hero
Fixes: 60
I only noticed it yesterday @bobpullen so a bit early to spot any patterns.
I've just done a gateway hop and everything is back to normal Huh
My Broadband Speed Test
bobpullen
Fixes: 316
@Terranova667 wrote:
... it seems my connection was reliant on the links that were turned off any idea when thy will come back into play I would rather have the previous problem than the one I have now.
That shouldn't be the case. There's plenty of capacity across the remaining links and your traffic won't have been 'pinned' to an individual link anyway.
Terranova667
Fixes: 5
Thanks for the reply Bob, it;s a strange one, I don't see how all of a sudden i'm unable to max my throughput nothing changed other than those links being disabled maybe the routing across the other links isn't as optimised as it was with the other links enabled ? they clearly effect something other wise why bother disabling them in the first place.
bobpullen
Fixes: 316
The more links, the better the redundancy, but they're not required at present to satisfy demand. We will be looking to bring them back into service at some point so it will be interesting to see what happens then. The reason they've been switched off is because they're having a detrimental impact on the traffic passing across them.
30FTTC06
Fixes: 4
Just for info. (over wifi)
No change here before or after, still no large drops or loss. I'll hang fire on the firmware I'm using though just out of curiosity.
00.01s Start testing DSL
00.28s Servers available: 8
00.36s pinging 7 locations
05.38s 16ms London, UK
05.38s 20ms St. Ghislain, Belgium, EU
05.38s 28ms Dublin, Ireland, EU
05.39s 31ms Darmstadt, Germany, EU
05.39s 31ms Amsterdam, Netherlands, EU
05.39s 32ms Frankfurt, DE, EU
05.39s 35ms Zurich, Switzerland, EU
05.41s 5 seconds measuring idle buffer bloat
10.72s Trial download normal
10.77s Using GET for upload testing
10.77s preference streamsDown set to 12
10.77s preference streamsUp set to 4
19.01s stream0 2.76 megabit St. Ghislain, Belgium, EU
19.01s stream1 2.73 megabit St. Ghislain, Belgium, EU
19.01s stream2 2.8 megabit London, UK
19.01s stream3 2.61 megabit Dublin, Ireland, EU
19.01s stream4 2.68 megabit London, UK
19.01s stream5 2.68 megabit London, UK
19.01s stream6 2.57 megabit St. Ghislain, Belgium, EU
19.01s stream7 2.52 megabit Dublin, Ireland, EU
19.01s stream8 2.64 megabit London, UK
19.01s stream9 2.57 megabit St. Ghislain, Belgium, EU
19.01s stream10 2.59 megabit St. Ghislain, Belgium, EU
19.01s stream11 2.63 megabit London, UK
22.18s End of download testing. Starting upload in 2 seconds
24.18s Using POST for upload testing
37.4s Upload report:
37.4s stream0 1.09 megabit St. Ghislain, Belgium, EU
37.4s stream1 1.09 megabit St. Ghislain, Belgium, EU
37.4s stream2 1.26 megabit London, UK
37.4s stream3 1.16 megabit Dublin, Ireland, EU
43.52s End of upload testing
43.52s Recording upload 4.6
43.53s Timer drops: frames=0 total ms=0 slip=0
43.53s END TEST
45.54s Total megabytes consumed: 54 (down:41.8 up:12.2)
Terranova667
Fixes: 5
Thanks again for the reply Bob, that does make sense, seems today all is back to normal I'm getting max throughput maybe it just needed settling down or something.
idonno
Champion
Fixes: 6
Interesting read. I've seen a decline in my upload speed over the past couple of weeks. Usually my upload speed is around 18/19Mb whereas lately its come down to about 16Mb but at times, is much worse. Sometimes on TBB speedtest the graphs are bad too. My download speeds though are about par for the course (no complaints there), indeed I see DLM has been increasing it upwards of late.
I've got a Jack Dinns Auto Speed tester on the go.The upload speed tests are very strange though, sometimes its reasonably fine, sometimes it is bad. Just doesn't make sense. Any ideas anyone? ThanksJD1.jpgTB2.jpgTTB1.jpg
Ever helpful. Grin Sure, I’d love to help you out. Now which way did you come in?
bobpullen
Fixes: 316
@idonno, your latency is bad on that left-side think broadband test. Are these speedtests wired or wireless and are you sure there's negligible other activity on the line when the tests are run?
For info, your traffic routes across a different part of the network to the issue I referenced here so whatever you're seeing, it isn't related.
legume
Been running my test cases and still good so marked as fixed.
For others still with issues - the symptoms don't really match what I saw and repeatedly tested, in that:
Upload wasn't affected.
If a connection was bad it was very consistent speed (well loss) wise. To London this resulted in 2mbit average, to further away lower.
There was never a test I did that changed speeds with peak/off peak or gave any significant speed variation over the life of the bad tcp connection.
