rDNS Update
Future
rDNS Update
Can someone from the plusnet team update ticket 178619411 and change the rDNS for me? Its been open for over a week.
I ordered static IP and would like the rDNS change, I don't know why you guys think its a good idea in the first place to use <username>.plus.com by default.
9 REPLIES 9
Fixes: 417
Re: rDNS Update
You used to be able to do it yourself. Try the link in this post  https://community.plus.net/t5/Fibre-Broadband/Change-reverse-DNS-entry-from-username-to-an-IP-or-ano...
Please let us know if it still works.
Future
Re: rDNS Update
Yes I used that, it just creates a support ticket
Fixes: 417
Re: rDNS Update
Sorry, I see that @Gandalf is around. Hopefully he will fix it for you.
Fixes: 1,600
Re: rDNS Update
Hi there.
This should be done for you now.
It should propagate over the next 24 hours.
Quenchmaster
Re: rDNS Update
Hi Gandalf,
I am currently having a similar issue on my request for an rDNS change. Would you be able to assist? support ticket 182680989
Many thanks in advance if you can.
MatthewWheeler
Fixes: 479
Re: rDNS Update
@Quenchmaster Sorry to hear this.
I'll get this done for you now
 Matthew Wheeler
munkfish
Re: rDNS Update
Same issue here, could someone please update my rDNS, ticket is here:
https://www.plus.net/wizard/index.html?p=view_question&id=183338521
Many thanks.
HarryB
Fixes: 256
Re: rDNS Update
Hi @munkfish,
Apologies for the delay in that ticket being picked up. I've submitted the requested change and this should take effect within the next 24 hours.
If that's not updated by this time tomorrow, please drop us a message here and we'll look in to that further for you.
I hope this helps.
 Harry Beesley
munkfish
Re: rDNS Update
@HarryB much obliged.
