problem with handshaking?
FIXED- Subscribe to RSS Feed
- Re: problem with handshaking?
13-02-2017 10:34 PM
I have had an issue starting recently that causes my connection to not respond when i open up a webpage or something similar. The page will usually time out and not load. This is resolved by refreshing the page usually.
In games i have to restart a bunch of times as the server list fails to load.
The connection itself seem fine, speeds are 50mb and pings are low with no packet loss, it just seems to be the initial handshake with the server.
Anything i can do/check to fix this?
Fixed! Go to the fix.
14-02-2017 11:00 AM
This thread is worth a read https://community.plus.net/t5/Fibre-Broadband/Slow-website-loading-and-constant-timeouts-over-the-pa... and might be the solution
15-02-2017 1:27 PM
8.8.8.8 as the dns looks to be working, cheers sir.
