power loss
- Re: power loss
power loss
10-12-2015 1:41 PM
as the topic says , i had a blip in my power supply for about 10 secs and that was enough to alter my line speeds
i was hitting about 60/18 but after the power loss im down to 18/12 , will the cabinet/exchange reset my line automatically and how long will this take or do i need to raise a fault
Message 1 of 4
(440 Views)
3 REPLIES 3
Re: power loss
10-12-2015 1:56 PM
have you tried a resync
Message 2 of 4
(213 Views)
Re: power loss
10-12-2015 2:42 PM
is there any online instructions
Message 3 of 4
(213 Views)
Re: power loss
10-12-2015 2:52 PM
Nope
The usual method is to disconnect from the internet using the browser interface to the router and then after a few minutes power down the modem then power up again
You may need to manually reconnect using the browser interface to the router
This assumes that you have a BT Modem and separate router but if you have a combined unit then you power down the router after disconnecting as above
Message 4 of 4
(213 Views)
