plusnet transparent proxy?
Today I started noticing some pages hanging strangely.
Then tried a url directly and it times out, however the error page wasnt my browser but a web cache from plusnet.
Note this error message.
"Generated Thu, 02 Apr 2015 10:25:30 GMT by pcl-iwfcache04.plus.net (squid)"
what gives?
the url is http://cloud.directupload.net/plugins/imageviewer/site/direct.php?s=1iTQ&/e70a04d6e95a97a2ebe4df412f... which loads fine when not loading via plusnet.
craigknighton
Re: plusnet transparent proxy?
That's the Internet Watch Foundation proxy server that is generating that error.
It's possible that the IP address that the file is originating from is on the black list, either though an error (happens a lot - especially with file lockers) or because it has been flagged as illegal content.
yeah that avatar image is really naughty :p not
sort it out plusnet.
other hosts affected include but not limited to
imageshack.us
postimg
dropbox
craigknighton
Not necessarily down to that one image, as cloud.directupload.net doesn't load at all for me, but directupload.net does.
Similarly the other sites you said all load perfectly for me.
Melancholie
If those three are all getting routed through the proxy cluster I'm not entirely surprised that it struggled. Not ideal but nothing untoward, just a rarity that all of them appear on the list at once.
I wouldn't be surprised if other ISPs with IWF filters had some issues - Virgin Media are famous for them.
Fixes: 10
I'm having issues as well - trying to load images such as http://s18.postimg.org/3wa54n0qh/Screen_Shot_2015_04_02_at_16_15_50.jpg
I've confirmed that I can view the images when I try using RDP to a desktop in the office (they are not on Plusnet) so the postimg.org server is fine.
I've rung in to report the issue.
jelv (a.k.a Spoon Whittler)
Mobile: iD mobile (£4/month)
deathtrap
The offensive imageS? This is exactly why the internet should not be censored/filtered, over blocking ? very lame and a massive FAIL!
Well yeah its common knowledge its trivial to bypass the IWF yet its still here.
Currently browsing with a socks, as these issues cause firefox to just hang in the middle of loading pages, when people have sigs etc. using these hosts.
Starmans
Does seem to be an issue unfortunately.
Able to load using Opera Turbo feature but not in another broswer.
still broken, so may not be load related.
Plusnet Staff
Plusnet Staff
Interesting that the link also works for me in Opera Turbo, but not anything else .... Anyway, I'm looking into it for you.
 Tony
 Plusnet Support
Fixes: 172
Doesn't opera go through its own cache with certain settings?
Customer / Moderator / If it helped click the thumb / If it fixed it click 'This fixed my problem'
Fixes: 4
Opera in turbo mode bypasses your dns setting entirely using port 443  Shocked
Quote from: plusnettony
ok thanks
guys if you cant/wont fix it can you at least set the timeout to something reasonable like 5-15 seconds, currently it sits there for THREE minutes before failing.
