turn on suggestions
plusnet hub zero
- plusnet hub zero
plusnet hub zero
plusnet hub zero
01-03-2015 9:20 AM
Hi not sure if this the right area for this post so sorry in advance can I get a free upgrade from the Technicolor router to the new plusnet hub zero
Thanks.
Thanks.
Re: plusnet hub zero
01-03-2015 11:36 AM
Afraid not they are for new customers only or i belive if you pay they will send you one but not for free, it's not worth it any way it's not any better than the router they use to send.
01-03-2015 11:38 AM
I joined at the beginning of the month and was sent the old one!
Fibre Broadband 80/20, Netgear D7000
