peer not responding
goatty2
peer not responding
this started yesterday had 8 peer not responding in the morning and another 4 today
it is not affecting the speed
not had this hapen before
anyone got an idea why it is doing this
noise magin has gone down
Noise margin:
5.4 / 5.2
Line attenuation:
32.6 / 23.5
normally runs at
Noise margin:
6.1 / 6.0
Line attenuation:
32.4 / 23.4
goatty2
Re: peer not responding
just done it again
it didn't matter when it did early morn but this is the second this afternoon
Fixes: 219
It looks like there has been a few drops recently
Testing isn't showing any issues but if it keeps occurring I'd recommend raising a fault using the link below.
https://faults.plus.net
 Matthew Wheeler
goatty2
ok Matthew
speed still the same and noise still lower but thinkbroadband test a bit wierd
http://www.thinkbroadband.com/speedtest/button/142866819283628058770.png
goatty2
not very good tonight
1. Best Effort Test: -provides background information.
Download Speed
19.35 Mbps
0 Mbps 37.13 Mbps
Max Achievable Speed
Download speedachieved during the test was - 19.35 Mbps
For your connection, the acceptable range of speedsis 25.99 Mbps-37.13 Mbps .
Additional Information:
IP Profile for your line is - 37.13 Mbps
Upload Speed
2.69 Mbps
0 Mbps 20 Mbps
Upload speed achieved during the test was - 2.69Mbps
AndyT
Hi goatty2,
Your connection seems to have stabilised over the weekend, but the throughput speeds you recorded yesterday are lower than we'd expect to see.  I can see you've begun to raise the issue through to our faults team to investigate on Ticket: 102430477.  Please could you complete the questions on the fault checker so they can investigate for you.
