odd speed issue
etdsaunders
Fixes: 7
odd speed issue
Hello,
It's been a long time since i've had any issues with plusnet (i even forgot my login details) however i've noticed a very odd issue and want to know if anyone has suffered it.
My hub one was faulty, so instead of getting a replacement i was given a HH5 (from family) which has been solid till today. Yes i've lost speed on my upload ONLY, download hasn't been effected. It's gone from solid 18mb to 13/14mb
Thoughts? Smiley
Edit: current stats from the router (noise and attenuation hasn't changed)
5. VDSL uptime: 0 days, 00:54:19
6. Data Rate: 14111 / 76416
7. Maximum Data Rate: 14111 / 77012
8. Noise Margin: 6.2 / 3.4
9. Line Attenuation: 24.3 / 18.6
Raspberry Pi enthusiast!
If you Like it, give it a Thumbs Up
etdsaunders
Fixes: 7
Re: odd speed issue
@Gandalf i've seen you mention cross talk on another thread, does this effect both upload and download? or could it effect one and not the other?
so in my example, my upload speed is below estimates. could cross talk do this?
Fixes: 538
Re: odd speed issue
Hi there. Yeah cross talk can affect both downstream and upstream speeds.
Testing your line isn't flagging up any problems.
Whilst the upstream rate is fractionally below your estimates, it may be that there's not much can be done to improve it. With that said, I'd say it's definitely worth getting this looked into by an engineer.
If nothing can be done, at least we'll know where we stand with your speed.
I'm assuming you've tried the usual checks/test socket etc?
I notice you've reported a fault to us online, so I'll update ticket 160633384 soon.
etdsaunders
Fixes: 7
Re: odd speed issue
Yeah i've done test socket etc, it's not touched my download speeds just my upload speed. Could it be router related? Undecided
Fixes: 538
Re: odd speed issue
That's a good shout and it's possible. if you're wanting a replacement Hub One to try, I'd happy to send another one out to you free of charge [except the P&P of £6.99 though].
etdsaunders
Fixes: 7
Re: odd speed issue
I've just responded to the ticket, please can we try a replacement hub firstly rather than wasting an engineer visit? Cheesy
Fixes: 538
Re: odd speed issue
Aye a different router is probably the best way forward.
I'll get one sent out to you now, at no cost.
etdsaunders
Fixes: 7
Re: odd speed issue
You are a star @Gandalf - i'm guessing the fault report can be put on hold till hub one arrives? Thumbs Up
The hub 5 did stop responding and had to reboot it, and then it dropped to the current poor upload speed. let's hope it's an easier fix Wink
Fixes: 538
Re: odd speed issue
No problems at all.
The fault report is currently sat with you and will close after 14 days of inactivity, but if your router doesn't arrive within that time, then there's something wrong with the post!
Let us know when you receive it. Smiley
etdsaunders
Fixes: 7
Re: odd speed issue
router arrived yesterday @Gandalf, just setup and upload has dropped bit more by the looks
5. DSL uptime: 0 days, 00:25:23
6. Data rate: 11868 / 72250
7. Maximum data rate: 11853 / 71313
8. Noise margin: 5.9 / 3.3
9. Line attenuation: 24.4 / 19.0
10. Signal attenuation: 24.3 / 19.0
