odd speed issue
FIXED- Subscribe to RSS Feed
- Re: odd speed issue
25-10-2017 1:23 PM - edited 25-10-2017 1:27 PM
Hello,
It's been a long time since i've had any issues with plusnet (i even forgot my login details) however i've noticed a very odd issue and want to know if anyone has suffered it.
My hub one was faulty, so instead of getting a replacement i was given a HH5 (from family) which has been solid till today. Yes i've lost speed on my upload ONLY, download hasn't been effected. It's gone from solid 18mb to 13/14mb
Thoughts?
Edit: current stats from the router (noise and attenuation hasn't changed)
5. | VDSL uptime: | 0 days, 00:54:19 |
6. | Data Rate: | 14111 / 76416 |
7. | Maximum Data Rate: | 14111 / 77012 |
8. | Noise Margin: | 6.2 / 3.4 |
9. | Line Attenuation: | 24.3 / 18.6 |
If you Like it, give it a
Fixed! Go to the fix.
Re: odd speed issue
26-10-2017 3:22 PM - edited 26-10-2017 3:23 PM
@Gandalf i've seen you mention cross talk on another thread, does this effect both upload and download? or could it effect one and not the other?
so in my example, my upload speed is below estimates. could cross talk do this?
Re: odd speed issue
26-10-2017 3:46 PM
Hi there. Yeah cross talk can affect both downstream and upstream speeds.
Testing your line isn't flagging up any problems.
Whilst the upstream rate is fractionally below your estimates, it may be that there's not much can be done to improve it. With that said, I'd say it's definitely worth getting this looked into by an engineer.
If nothing can be done, at least we'll know where we stand with your speed.
I'm assuming you've tried the usual checks/test socket etc?
I notice you've reported a fault to us online, so I'll update ticket 160633384 soon.
Re: odd speed issue
26-10-2017 5:07 PM
Yeah i've done test socket etc, it's not touched my download speeds just my upload speed. Could it be router related?
Re: odd speed issue
26-10-2017 5:15 PM
That's a good shout and it's possible. if you're wanting a replacement Hub One to try, I'd happy to send another one out to you free of charge [except the P&P of £6.99 though].
Re: odd speed issue
26-10-2017 5:16 PM
I've just responded to the ticket, please can we try a replacement hub firstly rather than wasting an engineer visit?
26-10-2017 5:27 PM
Re: odd speed issue
26-10-2017 5:31 PM - edited 26-10-2017 5:32 PM
You are a star @Gandalf - i'm guessing the fault report can be put on hold till hub one arrives?
The hub 5 did stop responding and had to reboot it, and then it dropped to the current poor upload speed. let's hope it's an easier fix
Re: odd speed issue
26-10-2017 6:35 PM
No problems at all.
The fault report is currently sat with you and will close after 14 days of inactivity, but if your router doesn't arrive within that time, then there's something wrong with the post!
Let us know when you receive it.
Re: odd speed issue
31-10-2017 10:22 AM
router arrived yesterday @Gandalf, just setup and upload has dropped bit more by the looks
5. DSL uptime: | 0 days, 00:25:23 |
6. Data rate: | 11868 / 72250 |
7. Maximum data rate: | 11853 / 71313 |
8. Noise margin: | 5.9 / 3.3 |
9. Line attenuation: | 24.4 / 19.0 |
10. Signal attenuation: | 24.3 / 19.0 |
