odd results from new fibre (today) installation
- odd results from new fibre (today) installation
05-02-2015 1:27 PM
Just had fibre installed this morning, getting some odd test results. Wireless off. New tp-link Archer c20i router being used.
Any thoughts would be good.
thanks.
Speedtest.net
BT wholesale as my plusnet user:...
1. Best Effort Test: -provides background information.
Download Speed
3.06 Mbps
0 Mbps 45.49 Mbps
Max Achievable Speed
Download speedachieved during the test was - 3.06 Mbps
For your connection, the acceptable range of speedsis 36.39 Mbps-45.49 Mbps .
Additional Information:
IP Profile for your line is - 45.49 Mbps
Upload Speed
11.02 Mbps
0 Mbps 20 Mbps
Upload speed achieved during the test was - 11.02Mbps
BT wholesale as speedtest@speedtest_domain:...
Download Speed
42.71 Mbps
0 Mbps 45.49 Mbps
Download speedachieved during the test was - 42.71 Mbps
Upload Speed
2.86 Mbps
0 Mbps 20 Mbps
Upload speed achieved during the test was - 2.86Mbps
Your service was found to be performing poorly.
Please raise a fault with your service provider, stating that the BT Performance Tester tool indicates poor service throughput performance after the third test.
thanks.
Speedtest.net
Download Speed
3.06 Mbps
0 Mbps 45.49 Mbps
Upload Speed
11.02 Mbps
0 Mbps 20 Mbps
Download Speed
42.71 Mbps
0 Mbps 45.49 Mbps
Upload Speed
2.86 Mbps
0 Mbps 20 Mbps
Message 1 of 4
(675 Views)
3 REPLIES 3
Re: odd results from new fibre (today) installation
05-02-2015 1:38 PM
Was your speed previously around 3Mb/s down on ADSL?
If so, probably just waiting for the Plusnet Profile ('Current Line Speed' as shown in the member centre) to be updated to your new FTTC speeds
Call me 'w23'
Message 2 of 4
(417 Views)
05-02-2015 2:15 PM
It was indeed. That was my first thought.
Thought i'd ask opinions before feeling any need to think fault.
Just checked. All looks good
<a href="http://www.speedtest.net/my-result/4118696646"><img src="http://www.speedtest.net/result/4118696646.png"></a>
Message 3 of 4
(417 Views)
05-02-2015 2:19 PM
Looks like the profile was updated on our side around 1pm, so hopefully everything carries on well for you here.
Message 4 of 4
(417 Views)
