numerous minor latency changes - ptn-ag03
Since gateway hopping to get off the BNG's my connection has been on ptn-ag03 for a few days.  Since going on it my TBB graph is showing numerous changes in latency.  Never had this before and not noticing any adverse affects, so checking if it smoke hiding a bigger problem.
Unvalued customer since 2001 funding cheap internet for others / DSL/Fibre house move 24 month regrade from 8th May 2017
Fixes: 62
Re: numerous minor latency changes - ptn-ag03
rongtw
Fixes: 12
I am also having a similar problem  Huh
Fixes: 16
You could check the traceroute to pingbox1.thinkbroadband.com to see if there are multiple routes or if the routing is changing.
Fixes: 149
I'm just looking into this now.
 Matthew Wheeler
