not sure bout fibre speed
patrick40
Ive recently had my service installed on 2nd june and only getting 38meg meant ot be getting 75 ....is this normal
Fixes: 188
Re: not sure bout fibre speed
Provisioned on the wrong package maybe?
Something for Plusnet CRT to check...
Customer and Forum Moderator. Windows 10 Firefox 64.0 (64-bit)
patrick40
Hi Strat  thanks for responding ....I had a live chat with a member of the plusnet live team and they checked and according to them im getting the 76meg line and he suggested t otry different wireless channels
if you use the BT Wholesale Performance Test and select 'Further Diagnostics' after the initial speed test, this will confirm your BT IP profile, also check the Plusnet Line Profile (referred to as 'Current Line Speed' here).
Please post the results Smiley
Call me 'w23'
patrick40
plusnet profile details ............Estimated line speed:
76Mb (Download speed could vary depending on line conditions. Estimates are the maximum speeds that your phone line can support. These speeds are dependent on the package you choose.) - Checked on 2015-05-18 13:28:50
Current line speed:
78 Mb
Fixes: 239
Your account is set up correctly and the line is testing absolutely fine.
Have you tried a wired connection?
 Matthew Wheeler
patrick40
Hi guys thanks for all the replys ..............i found out it was the wireless device on my computer wasnt transmitting full signal......................so using wired and all good ,,,my kindle was showing everything from day 1 Smiley    so all good thanks again
