not sure bout fibre speed
- Re: not sure bout fibre speed
04-06-2015 10:12 AM
Ive recently had my service installed on 2nd june and only getting 38meg meant ot be getting 75 ....is this normal
Message 1 of 7
(805 Views)
6 REPLIES 6
04-06-2015 10:25 AM
Provisioned on the wrong package maybe?
Something for Plusnet CRT to check...
Message 2 of 7
(544 Views)
04-06-2015 11:07 AM
Hi Strat thanks for responding ....I had a live chat with a member of the plusnet live team and they checked and according to them im getting the 76meg line and he suggested t otry different wireless channels
Message 3 of 7
(544 Views)
04-06-2015 11:25 AM
if you use the BT Wholesale Performance Test and select 'Further Diagnostics' after the initial speed test, this will confirm your BT IP profile, also check the Plusnet Line Profile (referred to as 'Current Line Speed' here).
Please post the results
Call me 'w23'
Message 4 of 7
(544 Views)
04-06-2015 11:41 AM
plusnet profile details ............Estimated line speed:
76Mb (Download speed could vary depending on line conditions. Estimates are the maximum speeds that your phone line can support. These speeds are dependent on the package you choose.) - Checked on 2015-05-18 13:28:50
Current line speed:
78 Mb
Current line speed:
78 Mb
Message 5 of 7
(544 Views)
05-06-2015 9:14 AM
Message 6 of 7
(544 Views)
06-06-2015 9:54 AM
Hi guys thanks for all the replys ..............i found out it was the wireless device on my computer wasnt transmitting full signal......................so using wired and all good ,,,my kindle was showing everything from day 1 so all good thanks again
Message 7 of 7
(544 Views)
