not get.n the speeds quoted buy plusnet
buddajamie
hi folks this is prob a reoccurring topic on this matter i have unlimited fibre,an quoted at 40mps ,when doing speed check being told it is reaching 39.9 mps
yet when i use my computer with a cable or WiFi the highest speeds i have achieved are 4.9mps this the same speed for wifi and cable the router is less than 10 feet from my laptop i have connected direct from BT socket and still the same highest 4.9mps
i raised a ticket and gave a contact time i was available but was phoned at work and asked the tech to phone me back that day at 6pm if possible that was a week ago and still no return call
i dont expect 40mps but i would like to at lease achieve 20mps  not happy paying for a service and it is not following through with its policys
buddajamie
13 REPLIES 13
PeeGee
Re: not get.n the speeds quoted buy plusnet
Can we get some clarification so that sensible responses can be made?
By "mps" do you mean "Mbps" or "MBps" - a difference of about 10x (allowing for overheads). A sync rate of 40Mbps should give a throughput of between 4 and 5 MBps.
Phil
Plusnet FTTC (Sep 2014), Essentials (Feb 2013); ADSL (Apr 2009); Customer since Jan 2004 (on 28kb dial-up)
buddajamie
4 MBs
Phil
buddajamie
4MBs down load speed on both wifi and cable
eddielenton
4 megabytes per second (4MB/s) is about right for someone on 40 megabits per second (40Mbps).
If you do a test at http://www.speedtest.net/ then you should see a speed result in megabits per second.
MasterOfReality
Fixes: 57
Hi @buddajamie
Welcome to the forums!
Sorry to hear you are getting poor throughput speeds. I've just ran a GEA test and I can see your router is syncing at 40.0 Mbps. The minimum estimate for your line is 32 Mbps, this estimate is created based on the known length of the line, joints and materials used to create the line. The line is performing well and within the expected limits with a sync rate of 40 Mbps.
This information was also sent to you off the back of the ticket you raised to us - click here to view this ticket and the reply from our faults team.
Can you run through our troubleshooting guides here and our Wireless troubleshooter here and then please run a wired speed test on BT Speed Test and complete the test right to the end.
Let us know how you get on.
buddajamie
Hi perhaps it just me but when i took out this product i never noticed or was informed that the estimated actual down load speeds( 38 to 40 MBS  will be a tenth of the speed (4.MBS)
we are told that their will be some drop of line speed approx a third
if what you are saying that 4 MBs is an acceptable speed for a fibre broadband quoting 40MBs i find that way below my expectations
Buddajamie
Strat
Fixes: 564
If you are on the 40Mbs package then 38Mbs or approximately 3.8 MBS is the absolute maximum you will get.
3.8MBS = 38Mbs.
Customer and Forum Moderator. Windows 10 Firefox 103.0.2 (64-bit (64-bit)
Browni
Aspiring Hero
Fixes: 52
You really need to make sure you are using the correct units, 40MBps is equal to 320Mbps.
pjmarsh
Fixes: 11
40Mbps is the max speed of the product not 40MBs.  Those 2 speeds are very different. 40 Mbps = 5MB/s.  4MB/s is 32Mbs, so by the time various overheads, wifi and any slowdowns with the speedtester and such like 32Mbs isn't too far off the throughput you should expect from a 40Mbps sync.
Edit: Slow typing tonight, everyone is getting in before me!  This isn't too bad for reading up on converting units.
buddajamie
I have just read your reply and i,am wondering if my math is different from yours
when i get a figure of 3.8 to me it means its 0 .2 short of 4 not 40
perhaps when you advertise your products then the 3.8MB/s speed rather than the 38MB/s speed is mentioned helping people who are not to aware of the difference (like me) as i would have taken my custom went else where
Buddajamie
dannyboy75
As others have said, you're confusing megabits and megabytes. ISP's always advertise speeds in megabits per second, this is a standard thing in the industry. There's no deception or subterfuge going on here.
However, web browsers tend to show download speeds in megabytes per second. There are 8 bits in a byte, so if connected to Plusnet at 40 megabits per second, you would expect to see maximum download speeds of up to 5 megabytes per second. (40/8 = 5). Bear in mind this is a theoretical maximum - in practice the speeds you'll see will probably be just short of this, if everything's working well (which it looks to be).
Most speed test websites give you the option to show results in MBps (megabytes/sec) or Mbps (megabits/sec), depending on your preference.
buddajamie
thanks
Fixes: 1,434
No worries. Let us know if you need any further help.
