no connection
rongtw
Fixes: 12
no connection
Oh dear I don't have internet this morning? Phone works , restarted router still nowt ?
Nothing on service status nothing on zen status ?
Router log says connection went off at 04.09 ?? And can't reconnect
All I get from router is time out waiting for PADO packets ?
And no way of contacting PN till later
Fixes: 311
Re: no connection
I always check https://status.zen.co.uk/broadband/ for the faults, but there doesn't seem to be anything open at the moment.
Customer / Moderator / If it helped click the thumb / If it fixed it click 'This fixed my problem'
tracymbuckley
Re: no connection
hi - NO BROADBAND SERVICE SINCE YESTERDAY AFTERNOON ,done all the usual steps as advised on plusnet website ,
this did not solve the problem , please advise .
rongtw
Fixes: 12
Re: no connection
Yes I did look at Zen status 👍
So after only 20 wait on phone ,nice polite PN engineer did some tests. 😎
Looks like I have a problem at my box or the exchange 48 -72 hours to get it checked by OR !!!!
Hopefully it may fix my speed problems
May have to increase my mobiles data allowance 😕
tracymbuckley
Re: no connection
no connection either ( barnsley area )   please advise if there is a problem
rongtw
Fixes: 12
Re: no connection
Hi according to Plusnet BT say there are no MSO , so loss of connection is just local
Fixes: 165
Re: no connection
@rongtw
Thanks for getting this reported, fingers crossed you're not waiting too long for it.
@tracymbuckley
Your issue is due to the router trying to connect with the wrong password.
You'll need to manually change the password your router is trying to connect with.
To do this:
- Open a web browser
- Go to 192.168.1.254
- Log in to the router if prompted (the username and password are printed on the router)
- Go to the broadband or connection settings
- Change the connection password to your password
- Click connect
 Chris Parr
 Plusnet Staff
rongtw
Fixes: 12
Re: no connection
I also hope it won't be to long , I can't sit and watch constipation street and hemoroid farm 😕 with swimbo tonight
tracymbuckley
Re: no connection
HI , thanks for the response.  Wondering why this problem has occurred as prior to the fault i have not touched the router , or disturbed it in any way  . Please advise .
                                                        Thanks   Tracey
Fixes: 165
Re: no connection
This is because you've changed your password on our website, and unfortunately as your router is quite old it's no longer registered on our side to automatically update this in your connection details. Once you update the connection password stored in the router to the same one you use to log in to www.plus.net you should be back online.
 Chris Parr
 Plusnet Staff
tracymbuckley
Re: no connection
Many thanks for your assistance and explanation to my issues , i did actually order a new router over 10 days ago ( we are moving house next month and have placed a new contract order so was advised to have one  ) i was told it would be posted out and i would be charged a postage fee of £6.99 which i agreed to . Unfortunately this has not materialised !   anything you can do ?
       Regards
                 Tracey
Fixes: 165
Re: no connection
I'll get that sent out for you, do you want it to your current or new address?
 Chris Parr
 Plusnet Staff
tracymbuckley
Re: no connection
Wow ,Great service , we move out on September 16th to new property   so best send to current address -
Moderator's note by Adie (Dvorak) address removed from public forum
Fixes: 165
Re: no connection
I'd remove your address from your previous post, this is a public forum. I'll get the router sent out now.
 Chris Parr
 Plusnet Staff
tracymbuckley
Re: no connection
Your  help and prompt replies to my issues are very much appreciated .  thanks again.
        TracySmiley
