new user poor speed
jimpotter2017
new user poor speed
hi.
so a new user to Plusnet.
have arrived home after holiday tot he new service.
i was told i should get between 62 - 80 mb .
current speed is 24mb.
i have come from a virgin 200mb connection and will be perfectly happy with 70 - 80mb.
is it normal for the speed to start off so low ?Huh
router is connected to the master socket etc.
thx jim
3 REPLIES 3
adamwalker
Fixes: 221
Re: new user poor speed
Hi Jim,
Cheers for deciding to join us and welcome to the forums too!
I've just been running diagnostics and everything looks in order from our point of view.
Are you connecting wirelessly? If so that may benefit from following the checks here: https://goo.gl/Bw9Upq
 Adam Walker
jimpotter2017
Hi Adam .
it was being checked via wireless .
although the previous router gave much better speeds and was also dual band.
i will run a wired check tonight , but last night bbc iplayer was stuttering .
not something that should happen even on a low speed connection
ill check out the checks you suggest
Jim
adamwalker
Fixes: 221
OK Jim, keep us posted and I'll make sure we follow things up as needed.
 Adam Walker
