new installation today
- new installation today
05-01-2015 3:12 PM
Hi
Engineer has just left i'm getting 11 - 17mbps upload but only 1.41mbps download.
Is this usual or do I need to do anything else.
Message 1 of 7
(827 Views)
6 REPLIES 6
Re: new installation today
05-01-2015 3:19 PM
you need to wait for your profile to be updated
Message 2 of 7
(505 Views)
05-01-2015 3:20 PM
Your order is not showing as complete yet. I think this is just a records issue that will sort itself out though.
I've changed your profile on our side from ADSL to Fibre, and I'm running a line test now which should re-start your connection. Once this is done, you should get full speeds.
Message 3 of 7
(505 Views)
05-01-2015 3:58 PM
hi i've just ran a further test and still only 1.2mbps, let me know when you have updated
Message 4 of 7
(505 Views)
05-01-2015 4:07 PM
Your profile on our side has updated, you may need to log in to your router and disconnect/connect once for any improved speeds to come through.
Message 5 of 7
(505 Views)
05-01-2015 4:36 PM
Hi do you mean via the IP address on the tool bar? if so the CP number on the router is invalid and doesn't allow me to log on.
I'll try a reboot!
I'll try a reboot!
Message 6 of 7
(505 Views)
05-01-2015 4:44 PM
much better 38mbps, from someone who had 1mbps i'm happy
Message 7 of 7
(505 Views)
