new installation today
kevincarb
Hi
Engineer has just left i'm getting 11 - 17mbps upload but only 1.41mbps download.
Is this usual or do I need to do anything else.
Fixes: 12
Re: new installation today
you need to wait for your profile to be updated
Fixes: 5
Your order is not showing as complete yet. I think this is just a records issue that will sort itself out though.
I've changed your profile on our side from ADSL to Fibre, and I'm running a line test now which should re-start your connection. Once this is done, you should get full speeds.
 Tony T
kevincarb
hi i've just ran a further test and still only 1.2mbps, let me know when you have updated
Fixes: 166
Your profile on our side has updated, you may need to log in to your router and disconnect/connect once for any improved speeds to come through.
 Chris Parr
 Plusnet Staff
kevincarb
Hi do you mean via the IP address on the tool bar? if so the CP number on the router is invalid and doesn't allow me to log on.
I'll try a reboot!
kevincarb
much better 38mbps, from someone who had 1mbps i'm happy  Smiley
