new gea test please
FIXED- Subscribe to RSS Feed
- new gea test please
Re: new gea test please
18-07-2018 1:35 PM
Hi @iangilf
As Gandalf said, we are currently waiting for an update from our suppliers. Once we have that we will be back in touch with you.
18-07-2018 4:09 PM
ok ta
18-07-2018 8:48 PM
also i see there is a newer hub one firmware can u push this threw to the router please as im currently using
Software version 4.7.5.1.83.8.237.2.2 Last updated 11/12/17
thankyou
18-07-2018 11:33 PM
@iangilf, does your serial number end '283'? If so, would you be able to factory reset the device and let me know once this has been done? I'm having difficulty communicating with your device and reports that it was last online months ago.
19-07-2018 6:55 AM
ok m8 ive done that cheers
19-07-2018 2:08 PM
@iangilf, all sorted
19-07-2018 2:54 PM
19-07-2018 3:35 PM
on 19-07-2018 7:28 PM - last edited on 19-07-2018 7:36 PM by Strat
Why no reply the lazy git of a bt engineer hasnt provided u with the update god i hate this
Moderator's note by Dick (Strat): All caps title/text edited as per Forum rules.
20-07-2018 9:24 AM
Sorry to hear that.
From what I can see your connection has been stable since the engineer visit.
It may be worth monitoring this and let us know if the drops continue or become more frequent so we can arrange another engineer visit.
20-07-2018 11:05 AM
20-07-2018 11:12 AM
No problems @iangilf
20-07-2018 7:16 PM
hi again gandalf m8 can u request the line has a dlm reset now as the engineer suggests that u are able to do this for me as my line was in fault but seems to have been resolved for the time being so would u please raise this with the appropriate people
thanks very much
21-07-2018 11:55 AM - edited 21-07-2018 11:56 AM
Hello @iangilf,
Thanks for getting in touch. We have checked your connection and placed the results below, which shows it is not banded and is operating towards the top end of your estimated speeds. As your line is not banded a DLM reset would not achieve any result as there is no banding to remove.
Test Outcome | Pass |
Test Outcome Code | GTC_FTTC_SERVICE_0000 |
Description | GEA service test completed and no fault found . |
Main Fault Location | OK |
Sync Status | In Sync |
Downstream Speed | 76.5 Mbps |
Upstream Speed | 20.0 Mbps |
Appointment Required | N |
Fault Report Advised | N |
NTE Power Status | PowerOn |
Voice Line Test Result | Pass |
Bridge Tap | Not Detected |
Radio Frequency Ingress | Not Detected |
Repetitive Electrical Impulse Noise | Not Detected |
Cross Talk | Not Detected |
Estimated Line Length In Metres | 377.3 |
Upstream Rate Assessment | Very Good |
Downstream Rate Assessment | Very Good |
Interference Pattern | Not Detected |
Service Impact | No Impact Observed |
Home Wiring Problem | Not Detected |
Downstream Policing Discard Rate | 0.0 |
Customer Traffic Level | Upstream and Downstream Traffic Detected |
Technology | VDSL |
Profile Name | 0.128M-80M Downstream, Error Protection Off - 0.128M-20M Upstream, Error Protection Off |
Time Stamp | 2018-07-18T12:00:00 |
Parameters | MIN | MAX | AVG |
Down Stream Line Rate | 76.3 Mbps | 76.5 Mbps | 76.4 Mbps |
Up Stream Line Rate | 20.0 Mbps | 20.0 Mbps | 20.0 Mbps |
Up Time | 785.0 Sec | 900.0 Sec | 898.8 Sec |
Retrains | 0.0 | 1.0 | 0.0 |
Current and Last 15 Minute Bin Performance | ||
Parameters | Last Traffic Count(Upto 15 mins) | Current Traffic Count(Upto 15 mins) |
Start Time Stamp | 2018-07-21T11:16:45.181+01:00 | 2018-07-21T11:31:45.181+01:00 |
Ingress Code Violation | 0 | 0 |
Egress Code Violation | 0 | 0 |
Errored Seconds | 0 | 0 |
Severely Errored Seconds | 0 | 0 |
Unavailable Seconds | 0 | 0 |
21-07-2018 12:02 PM
