new gea test please
FIXED- Subscribe to RSS Feed
- new gea test please
Re: new gea test please
22-06-2018 2:12 PM
22-06-2018 2:37 PM
22-06-2018 3:06 PM
22-06-2018 3:59 PM
5. DSL uptime: | 0 days, 00:04:52 |
6. Data rate: | 20000 / 76636 |
7. Maximum data rate: | 25895 / 76716 |
8. Noise margin: | 9.4 / 6.0 |
9. Line attenuation: | 17.5 / 14.3 |
10. Signal attenuation: | 17.3 / 14.3 |
just changed router back to the lantiq chipset can u set the right ip profile for my line and synce speed thankyou as still getting slower throughput than should be if not can u request an engineer visit again as its not working how it should be but im sure if you set the right bras ip profile it should sort this
22-06-2018 4:00 PM
We can set the levels at our side at the maximum we can, but if the bRAS hasn't increased on BT's side, it won't make any difference to you. That said, I have made the change for you in preparation of a bRAS increase. It's possible that our reporting will lower it again if the bRAS doesn't increase first.
22-06-2018 4:04 PM
hi tony here is current speedtest
http://www.speedtest.net/result/7414057078
same as before
do u know when u make any changes shouldnt my line disconnect and reconnect and does it matter that im on a static ip address to any of this?
22-06-2018 5:14 PM
22-06-2018 5:23 PM - edited 22-06-2018 5:30 PM
http://www.speedtest.net/result/7414260395
is 71 meg speedtest right for that ?
yep m8 did the trick thankyou tony for helping me hopefully it will stay it didnt before when matt did it so dont get mad with me if i have to ask again if it goes again cheers m8
22-06-2018 5:31 PM
26-06-2018 3:21 PM
can i have a gea test please
thanks as i would like to compare if u dont mind of course
26-06-2018 4:23 PM
GEA Test Detail | |||
Circuit ID | NA | Service ID | BBEU22614246 |
Test Outcome | Pass | ||||
Test Outcome Code | GTC_FTTC_SERVICE_0000 | ||||
Description | GEA service test completed and no fault found . | ||||
Main Fault Location | OK | ||||
Sync Status | In Sync | ||||
Downstream Speed | 76.5 Mbps | ||||
Upstream Speed | 20.0 Mbps | ||||
Appointment Required | N | ||||
Fault Report Advised | N | ||||
NTE Power Status | PowerOn | ||||
Voice Line Test Result | Pass | ||||
Bridge Tap | Not Detected | ||||
Repetitive Electrical Impulse Noise | Not Detected | ||||
Estimated Line Length In Metres | 382.0 | ||||
Upstream Rate Assessment | Very Good | ||||
Downstream Rate Assessment | Reasonable | ||||
Interference Pattern | Not Detected | ||||
Service Impact | No Impact Observed | ||||
Home Wiring Problem | Not Detected | ||||
Downstream Policing Discard Rate | 0.0 | ||||
Customer Traffic Level | Upstream and Downstream Traffic Detected | ||||
Technology | VDSL | ||||
Profile Name | 0.128M-80M Downstream, Interleaving Low - 0.128M-20M Upstream, Error Protection Off | ||||
Time Stamp | 2018-06-13T16:30:00 |
Parameters | MIN | MAX | AVG |
Down Stream Line Rate | 68.5 Mbps | 76.6 Mbps | 75.6 Mbps |
Up Stream Line Rate | 20.0 Mbps | 20.0 Mbps | 20.0 Mbps |
Up Time | 615.0 Sec | 900.0 Sec | 898.9 Sec |
Retrains | 0.0 | 2.0 | 0.0 |
Current and Last 15 Minute Bin Performance | ||
Parameters | Last Traffic Count(Upto 15 mins) | Current Traffic Count(Upto 15 mins) |
Start Time Stamp | 2018-06-26T16:01:27.691+01:00 | 2018-06-26T16:16:27.691+01:00 |
Ingress Code Violation | 0 | 0 |
Egress Code Violation | 0 | 0 |
Errored Seconds | 0 | 0 |
Severely Errored Seconds | 0 | 0 |
Unavailable Seconds | 0 | 0 |
26-06-2018 4:27 PM
26-06-2018 4:33 PM
26-06-2018 4:34 PM
26-06-2018 4:47 PM
