new gea test please
FIXED- Subscribe to RSS Feed
- new gea test please
Re: new gea test please
08-08-2018 11:15 AM
Hi @iangilf
Thanks for the update,
If you just drop us a message once your engineer has been on Thursday.
08-08-2018 1:02 PM
09-08-2018 7:25 AM
newest stats are much better with a healthier snr so there was obviously something wrong up the pole or with the pair as thats what they been doing this morning , can you please run another GEA TEST for me please and thankyou very much as long as it stays stable now fingers crossed
1. Product name: | Plusnet Hub |
2. Serial number: | +081441+NQ54605283 |
3. Firmware version: | Software version 4.7.5.1.83.8.259 Last updated 19/07/18 |
4. Board version: | Plusnet Hub One |
5. DSL uptime: | 0 days, 00:13:42 |
6. Data rate: | 20000 / 79995 |
7. Maximum data rate: | 31344 / 86212 |
8. Noise margin: | 12.5 / 7.7 |
9. Line attenuation: | 17.6 / 14.1 |
10. Signal attenuation: |
17.5 / 14.1 |
09-08-2018 9:02 AM
09-08-2018 9:07 AM
09-08-2018 9:32 AM
09-08-2018 9:42 AM
09-08-2018 9:50 AM - edited 09-08-2018 9:53 AM
Bit confused really because on ADSL2+ if snr reduced the higher sync rate will be. For FTTC if snr were reduced, then the sync rate will reduced unless DLM put target SNR 3dB to get the line back to higher sync rate with G.INP on it. But sometimes lower snr can cause lots of problem on ADSL2+ and FTTC with lots of disconnection etc.
I am try to find out how to get my snr back to 9.3dB but I do think the factor to do with more customers connected at my cabinet probably fill up that caused my snr rate to drop slightly now. After 4 years of FTTC with max rate 80Meg is now fallen behind at 78Meg for now, hope it not going down to 60Meg
Even worsen case my DSL CHecker used to show G.Fast as planned with a speed of 250/35 but it now disappear as an email from Openreach stated that my exchange are due for this month this year but now pushed back the date until end of next year because the exchange need upgraded to support g.fast.
09-08-2018 12:45 PM
09-08-2018 12:49 PM - edited 09-08-2018 12:51 PM
09-08-2018 12:55 PM
09-08-2018 1:00 PM
09-08-2018 10:26 PM - edited 09-08-2018 10:27 PM
best speedtest ive ever had and plugged in the bt hub 6 now and the stats are ok
http://www.speedtest.net/result/7539772666.png
20.00 Mbps / 79.99 Mbps
31960 / 84569
12.9 dB / 7 dB
14.3 dB
09-08-2018 10:40 PM - edited 09-08-2018 10:43 PM
I used to have that but sadly I am no longer at 79999K as I don't know why my fibre drop in sync rate
Just enjoy it while it last before DLM bite u!
Here is my stats from Hub One:
4. Board version: Plusnet Hub One
5. DSL uptime: 0 days, 00:33:35
6. Data rate: 19999 / 77735
7. Maximum data rate: 26077 / 78295
8. Noise margin: 15.0 / 6.1
9. Line attenuation: 13.1 / 11.2
10. Signal attenuation: 13.0 / 11.2
09-08-2018 10:42 PM
good evening m8 who knows how long it will last but whilst it seems stable and maximum speeds i cant really ask for more have u tried a different router or new lead from socket to modem router?
