new gea test please
FIXED- Subscribe to RSS Feed
- Re: new gea test please
14-06-2018 2:16 PM - edited 14-06-2018 2:20 PM
14-06-2018 4:32 PM
18-06-2018 11:01 AM
just another quick question
these are my stats , but when the engineer left my max attainable was over 81000 but now its in line with my sync rate do plusnet cap this speed aswell ? if so can i get the ip profile of 80 meg please which hopefully u can do your end and remotely like u did increase the speedtest for me thanks in advance
5. DSL uptime: | 4 days, 04:23:07 |
6. Data rate: | 20000 / 75680 |
7. Maximum data rate: | 26258 / 75680 |
8. Noise margin: | 9.4 / 5.8 |
9. Line attenuation: | 17.6 / 14.3 |
10. Signal attenuation: | 17.4 / 14.3 |
18-06-2018 3:31 PM
18-06-2018 5:15 PM
ok mate just seems odd as it was showing a higher attainable rate which has now dropped in line with my sync rate but thanks all the same tony fiber is a weird and wonderful thing lol
20-06-2018 7:25 PM - edited 20-06-2018 7:28 PM
current stats
my threwput is stuck at 67 meg download again can u make the changes what u did before to increase the threwput why is this happening ?
shoots all the way up over 70 meg then goes down to 67 meg dead on why has it changed again ?
http://www.speedtest.net/result/7409019485
5. DSL uptime: | 0 days, 00:11:12 |
6. Data rate: | 20000 / 76147 |
7. Maximum data rate: | 26714 / 76088 |
8. Noise margin: | 9.5 / 6.0 |
9. Line attenuation: | 17.5 / 14.3 |
10. Signal attenuation: | 17.3 / 14.3 |
11. Data sent/received: | 159.1 MB / 693.6 MB |
20-06-2018 7:55 PM
Hi @iangilf,
Upon testing your line and looking at the test results that you have sent us, everything appears to currently be working fine, despite the speeds being towards the lower ends of you estimated range. As this is the case I'm afraid there's nothing from our side that we could change at the moment to improve the throughput speeds that you are currently receiving.
20-06-2018 8:01 PM - edited 20-06-2018 9:39 PM
yes there is read back someone made some changes remotely its your end as always fedup of this every time its your end not mine it was fixed the other day and now gone back to how it was u dont get 67 meg speedtest results on a 76 meg connection matt sorted it last time i wished u lot would stop messing about with my line and just leave it alone after the changes are done , can see why people get fedup here on plusnet u say u run tests but it dont show anything up until yesterday everything was fine yes the line syncs at 76 meg and i was getting 71 meg download speedtests and matthewwheeler made changes remotely which fixed this and u tell me u cant do nothing your end lol and u wonder why people get frustrated cause running tests your side dont fix nowt maybe if u made some changes it would get fixxed but all we hear is we ran tests and nothing can be done lol its all jokes
Download speedachieved during the test was - 65.96 Mbps
For your connection, the acceptable range of speedsis 40 Mbps-73.71 Mbps .
Additional Information:
IP Profile for your line is - 73.71 Mbps
Phone exchange:BROADSTAIRSEstimated line speed:80Mb (This may vary between 60Mb and 80Mb) - Checked on 2017-10-15 23:36:52Current line speed:70.2 Mb
is my line profile u hold its a bit out dated dont u think i think these are the causes of the lower threwput it reflects the 70 meg download grrrrrr why is this profile u hold so old ?
so is your side that the problem exists ip profile for my line is 73 meg so 66 meg download speed is not acceptable , why cant u just do what matthew did before and make the changes ?
plusnet is becoming a drain on my life
21-06-2018 9:11 AM
Hi Ian,
Thanks for coming back to us.
I've just retested your line and your broadband is currently syncing up at 76.2mb/s.
I can confirm that the profile for your line is still set to the maximum and that no further changes have taken place since interleaving was enabled last week.
Could you please confirm what speeds you're seeing on a wired connection via the BT test socket?
Best wishes,
Dave
21-06-2018 9:55 AM
21-06-2018 12:59 PM
I've run a line test for you and added it to the account. It does appear that some form of interleaving has been applied to your line though. I've checked the stability levels which are all as expected. Unfortunately on Fibre, there is no quick way to change settings such as this. I've looked into the changes made by Matt, and there is nothing that I can reverse to change the situation without logging a new fault and having a possible engineer.
22-06-2018 11:15 AM
22-06-2018 1:00 PM
We don't actually have a way to switch off interleaving I'm afraid, other than waiting for the dynamic line management to see that it's no longer required. This may then switch it off. The only other options aren't available to us as the line speed isn't banded. Sorry to bring this bad news.
Tony
22-06-2018 1:13 PM
22-06-2018 2:07 PM
