new fibre user trying to understand speeds
markham0212
just received email with link to member centre saying my estimated line speed is 16mbps, which is above what i get on the bt wholesale speed checker, (about 12-15) with a current line speed of 40. it does say the estimated line speed will be a "little lower" than the current speed, but this is a lot less. is this fairly normal?
Re: new fibre user trying to understand speeds
I think the Email may be referring to the ADSL estimate (it's something I've raised here).
 Tony T
xreyuk
Put your phone number in here: https://www.dslchecker.bt.com
That'll tell you what the min/max estimates are for a clean FTTC, and an impacted FTTC line. The estimates you should be given, will be based on a clean FTTC line.
