much improved since new hub 1 installed
- Re: much improved since new hub 1 installed
12-05-2016 6:19 PM - edited 12-05-2016 6:21 PM
12-05-2016 7:04 PM
12-05-2016 7:28 PM
according to bt 1800 mtrs away from cab
12-05-2016 7:31 PM
12-05-2016 8:07 PM - edited 12-05-2016 8:10 PM
@tonyt2764 I would expect your cab to be much much much closerto you if you are pulling close to the 80Mb speeds, I'll have a gander tomorrow and see if I can find anything out for you
EDIT: Just realised you probably mean cab to exchange, that would make more sense, i assume however you can see your cab from your home at least given the speeds
@Casey If you'd like I'll take a check tomorrow and pop you a message over confirming the speeds you should expect to get, If you want to PM me your landline number I can do a few checks from here but won't be as accurate of course
12-05-2016 8:12 PM - edited 12-05-2016 8:46 PM
just had another look and is is the exchange that is that far away not cab my bad read it wrong all i know about cab is that it is cab 78 in yeovil somewhere not anywhere near my house as all of them different numbers
just found this site http://www.kitz.co.uk/adsl/cabinet-lookup.htm#fttc_cab
